No offense but that was a terrible reply. You didn't answer any of my questions. And yeah, best for on road and off road, and the biggest burden on the budget. They are nice, But this will hardly be used on the road.
While I agree that his reply didn't fully answer your questions, it was a responible answer to a suggestion.
Lunch-box lockers suck. Period. Yeah, they "do" the job, but the consiquences aren't pretty. Lunch-box Lockers (ie. Lock-Bites, slEZ-Lockers) put un-needed stress on the shafts with the constant loading and unloading. Things that have happened to my and my buddy
1) Snapped shafts (loading/unloading issue)
2) Broken Stock Sidegears (OEM is not 4340)
3) Broken 1530 sidegears (even Lock-Bite sidegears are crappola)
4) Broken Sidegears that break the carrier
5) So many munched pins and springs in ain't funny
All of these thing happened to lockers installed professionally by an ASE A tech.
If you are on a budget, and don't wheel much or won't be in the sport for long, then a Lunch-box will be fine. But over time, the costs for repairs may add up. Maybe more than an ARB
As for the spool, if it's trail only, it's the better bet. With 4340 steel, the spool won't shatter like sidegears do when a shaft fails. And it has predictable trail manners, not the loading/unloading crappola and nasty *snap* noises lunch-boxes are notorious for.
For the best, it's a selectable locker, such as KAM or ARB. These allow full spool or wide open, all at the flick of a switch. Damn nice, and you pay for that damn nice feeling.
My GV has an ARB rear. Since it was roaded, I wouldn't have it any other way.
My Sammy *had* 1510 lockers. I hate them now. I recently put a mini-spool in the rear (its a trail rig), and I'm build a hybrid front with an ARB up there. Locked when I need it, open when I don't.
Of course, this is advice on what you *should* run, even though you didn't ask for it.
