Auto trans
  • 14 Replies
  • 2423 Views
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Auto trans
« on: December 09, 2004, 02:34:49 AM »
Well my dad just bought a 97 tracker and his tcc lockup isnt working. He also has a code 740 tcc ckt. I checked the ckt. all ok the ecm is trying to apply tcc but to no avail. Can you change the tcc solonoid from the pan or do you have to pull the trans.
  Thanks,
   Kevin
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Auto trans
« Reply #1 on: December 09, 2004, 05:52:53 AM »
Well it's fixed ;D and you can replace the solonoid from the pan
Re: Auto trans
« Reply #2 on: December 09, 2004, 03:06:49 PM »
That's good to know, I don't think mine
has worked for 100,000 miles   :)
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Auto trans
« Reply #3 on: December 10, 2004, 02:29:23 AM »
Hey wild we need to hook up. I live in Murrieta just down lambs canyon from you.
Re: Auto trans
« Reply #4 on: December 10, 2004, 12:45:20 PM »
Ya, last trip was a bust as one of your friends
had passed away :( .
I will be out at Occotillo Wells for New Years,
Look for the red door and 33 Swampers  ;)
« Last Edit: December 10, 2004, 12:46:26 PM by wildgoody »
Offline Toolman
  • 10
Re: Auto trans
« Reply #5 on: December 12, 2004, 01:26:41 AM »
Hey ppltrak or wildgoody if you guys have auto trans could one of you do me a favor?
Where the TV kick down cable attaches to the throttle with a little black clip could you tell me if the end of the cable is tight up against the black clip or does the cable stick out about an inch or so?
MIne sticks out about an inch and I don't know if it is stuck in the transmission or if thats the way it's supposed to be.  It does move at full throttle but does not retract all the way.
Thanks
97 Chevy Tracker, Auto, 2" suspension, 2" body lift
5:12 gears, 30X9.50X15
Re: Auto trans
« Reply #6 on: December 12, 2004, 04:00:52 AM »
That is normal, if it is tighter (not tight)
it will kick the trans down sooner, or
if your trans kicks down too much or
too soon, make it a little longer or loosten
it so the trans stops going into second
as soon
Offline Toolman
  • 10
Re: Auto trans
« Reply #7 on: December 12, 2004, 02:12:24 PM »
Thanks.
I hadn't really seen a kick down cable that didn't come back all the way.
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Auto trans
« Reply #8 on: December 28, 2004, 06:45:09 AM »
Well Wild I just might have to head out to Occotillo this weekend.  ;D I'll be the purple tracker with green splash it was one of those splash models. Where are you going to camp? I normally camp near the ranger station so if you see me feel free to pull in.
Offline 96track
  • 66
  • THESE JEEP FREAKS WILL NEVER LEARN!!!
Re: Auto trans
« Reply #9 on: December 28, 2004, 10:40:34 AM »
hey while were on the topic, does anybody have picks or a passed thread on how to drop a 3 speed 96 tracker auto trans, mine is slipping and needs to be replaced.
96 track  2 inch susp, 3 inch body,512's, 4.24 to 1, rear locker, 31x12.50 boggers, warn 8000, custom front and rear bumbers. lined and diamond plated interior.
1988 sammy  spoa with cj's rear and rears up front, 4.16, rear locker, 31x 12.50 boggers, full cage by migoffroad .com
the silver sammy is mine, they use it as a display for there cage work.
Re: Auto trans
« Reply #10 on: December 28, 2004, 12:19:15 PM »
I'll be close to the hard pack dirt road, my Folks are
comeing in a motorhome, so they stay close to the
hard stuff, they got stuck once  ;)
The Motorhome is a Sports Coach with a blue stripe
and you know what the Kick looks like, This will be fun
See you out there
Re: Auto trans
« Reply #11 on: December 28, 2004, 12:21:07 PM »
Sorry, Mine has never been out of the trucklet
I would drop the T-case and cross member and
undo the engine bolts 4 big and some little ones
on the bell housing
Good Luck
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Auto trans
« Reply #12 on: December 29, 2004, 02:06:33 AM »
Hard packed dirt road? east of the airport or near blow sands? I might just do a day trip, the wife wants to go to a new years party.
Re: Auto trans
« Reply #13 on: December 29, 2004, 02:38:18 AM »
I've only been there the once,
go past the market/gas, then on the right
I think it's the state  rec area, they have
showers and toilets there, sound familiar ?
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Auto trans
« Reply #14 on: December 29, 2004, 02:59:24 AM »
I know where your talking about. there are some mud hills out past there ;D And they just might be muddy ;D
    See ya,
        kevin
