Coolant leak out of the back of my 1.6
Element
1902
LillyKicker
March 07, 2007, 04:42:16 PM »
I am leaking coolant from where the tranny and engine come together... A freind said it is most likely the freeze plugs... head gasket was replaced not too long ago. Anybody know anything about doing this project?
Jerry Member since: May 14, 2006
zUkTAH
U4WDA
daddyizzle
728
Colorado is still my home!!
Re: Coolant leak out of the back of my 1.6
March 07, 2007, 06:18:18 PM »
Any possibility it's leaking out of a heater hose and seeping back to where it appears like some kind of another leak?
-Adam
96Kicker
1043
http://www.zukiworld.com/forum/gallery/3710_25_10_
March 07, 2007, 08:51:42 PM »
A heater hose would be alot easier than pulling a engine to replace the freeze plugs.
Lets hope that is all it is jerry,that will save us alot of time before moab.
<a href="
http://s220.photobucket.com/albums/dd126/fletcher9160/?action=view¤t=Zuktahgreenblur.jpg
" target="_blank"><img src="
http://i220.photobucket.com/albums/dd126/fletcher9160/Zuktahgreenblur.jpg
" border="0" alt="Zuktah club sticker"></a>TJ
#801-554-3281
96 kick 4 door with custom 3 inch susp lift and pre runner front bumper,2 inch bod
ROSS
1412
WHY TAKE A PICTURE WHEN YOU CAN DRIVE OVER IT
Reply #3 on:
March 07, 2007, 08:54:16 PM »
jerry check your email
87 SAMI 1600 FUEL INJ. , TORQUER CAM, 6.5 TO 1T-CASE, 5"SPRINGS SHACKLE REVERSE ,2 BODY LIFT, LOCK-RITES FRONT W/ HEAVY-DUTY AXLES & ARB'S REAR BFG 31 X10.50 X 16", EXO SKELLETON,
Element
1902
LillyKicker
Reply #4 on:
March 07, 2007, 09:05:01 PM »
I will take a better look... The engine looked dry on top... I hope it is something easier!!!
zUkTAH
U4WDA
ROSS
1412
Reply #5 on:
March 07, 2007, 09:08:51 PM »
get up on top with a brite light and realy double check . even have someone else look
Element
1902
LillyKicker
Reply #6 on:
March 07, 2007, 09:10:48 PM »
Is my 65 lumen 6p Surefire bright enough???
zUkTAH
U4WDA
ROSS
1412
Reply #7 on:
March 07, 2007, 09:12:35 PM »
don't blind yourself. you gotta drive at moab in three weeks
Element
1902
LillyKicker
Reply #8 on:
March 07, 2007, 09:15:18 PM »
LOL! My wife hates that Toomey gave me a surefire as a gift....It will never get old to me showing someone how bright my little flashlight is...LOL! How does this sound? I can replace the heater hose and see if I still leak... iff so... pull the engine on friday! By the way... Where is the heater hose...lol
zUkTAH
U4WDA
ROSS
1412
Reply #9 on:
March 07, 2007, 09:21:35 PM »
look at the firewall . you can see both and follow them
one goes to the tube that comes out of the waterpump the other goes to firewall
heater control valve then to the intake. theres also a couple small ones
Jeremiah
1880
Viva La ZUKIWORLD!
Reply #10 on:
March 08, 2007, 12:31:43 PM »
I thought for SURE my head gasket went on my sami, but it ended up being a coolant hose that came to the back of my carborator. $1 fix. Look carefully, and make sure you know where that leak is comming from.
ROSS
1412
Reply #11 on:
March 08, 2007, 06:10:15 PM »
Jerry
how bad does it leak?? find a little dutchman to put his finger in the hole
Element
1902
LillyKicker
Reply #12 on:
March 08, 2007, 06:22:09 PM »
LOL... would that be safe? Not so much for the dutchman, but my vehicle... he could get all wrapped up in my driveline or something... The leak is bad enough that it bothers me... it has a slow constant drip....
zUkTAH
U4WDA
ROSS
1412
Reply #13 on:
March 08, 2007, 06:33:31 PM »
did you check everyhere?? all hoses , connections, clamps
