Samurai Engine, need some help
  • 1607 Views
Offline Amilla
  • 1076
« on: March 05, 2007, 02:17:41 PM »
Iv got an 88 samurai, and the engine is cutting out when ever load is being put on it.
its not the clutch slipping, im pretty sure its a fuel thing.
If im in 1st gear and try to take off a little faster then normal, it hops and lurchs.  Like the engine is cutting out kind of thing.  But if im driving dowe the road in say 3rd gear, and decide to just romp on it will just accelerate smoothly.
It also seems like its loading up on fuel, its backfireing quite a bit.
I already got a new O2 sensor for it, and that smoothed out the idle but nothing to stop the backfireing.
If anyone has some info
any is better than none.
Thanks
Amilla
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: Samurai Engine, need some help
« Reply #1 on: March 05, 2007, 02:54:10 PM »
Which carb do you have. Also, your wires are all good including the wire to the coil?
-Adam
Offline Amilla
  • 1076
« Reply #2 on: March 06, 2007, 07:45:01 AM »
I have the stock carb, its a remanufactured one but its still a stock carb.
I looked over all the wiring and it seemed fine.
anyone else got any ideas?
Thanks
Amilla
Offline RHodge
  • 523
« Reply #3 on: March 06, 2007, 04:51:01 PM »
I think thats what the Vent Tube Kit is for
You can get a most any Suzki place
Ryan
Offline daddyizzle
  • 728
« Reply #4 on: March 06, 2007, 05:33:16 PM »
Maybe the cap. Spark jumping around in it? I had a cap that looked perfect but had a hairline crack that caused a similar problem. Couldn't hurt to swap one out along with the rotor. I also keep an extra coil wire around for test purposes since alot of times you can't see a problem visually.
-Adam
Offline daddyizzle
  • 728
« Reply #5 on: March 07, 2007, 09:55:50 AM »
I had another thought on your engine problem. My old samurai acted like that when the fuel pump was going out. Yours may be weak. I think the suzuki dealer has new mechanical ones for around 40. That's as cheap as I have found for a new with gasket.
-Adam
Offline 4maddog
« Reply #6 on: March 09, 2007, 10:50:12 AM »
all yor plugs and ht leads in good shape aswell as dizzy cap? check your fuel lines they are quite bad for corrosion my sami had a small leak on the corroded line that was hard to see but made engine cut out load bearing at low rpm.
ITS ONE LIFE LIVE IT
Offline Amilla
  • 1076
« Reply #7 on: April 08, 2007, 11:57:36 AM »
I have just not fixed the problem, and stopped all engine cutting out.
The whole time the only problem was, the wire that goes to the distributer (off the wiring harness) was wraped up and hangin up on the distributer.  Everytime the engine would do a quick rev, the engine would move pulling the wire out then it would kill it, return back to touching together then start again.
Just got done connecting it back together and now it runs beautifuly.
Thanks for all the information and ideas posted.
much appreciated
Thanks
Amilla
