Cherry Bomb on a Sidekick?
  • 20 Replies
  • 6298 Views
Offline echojeff
  • 414
  • Lo que sea
Re: Cherry Bomb on a Sidekick?
« Reply #15 on: March 06, 2007, 07:37:58 PM »
http://www.youtube.com/watch?v=BHi_yK_xQHM
at the end of the video you can hear mine with the cherrybomb
Actually I liked the Yota's sound better ;D
I guess that yould mean an upgrade, too bad.
95 Kick 4dr JLX.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #16 on: March 07, 2007, 05:08:19 PM »
I have one of these, and while it doesnt seem that loud to me, it seems to be getting louder
Usually, that means that the fiberglass is blowing out of it, which is the main disadvantage of a glasspack muffler.
I didn't know they still made Cherrybombs.  Those things were around back when I was in high school, but most of the guys went for their main competitor's product, the "Thrush".  Maybe it was just because Thrush had a cooler logo, the angry looking bird with the cigar...
Jim Z.
66 Apache camper
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« Reply #17 on: March 07, 2007, 06:57:49 PM »
I have been thinking about doing the same thing to my 98 Tracker.  Can somebody tell me the inlet and outlet diameter that I need to get to replace my stock muffler with a glasspack?
my 94 track had 1 3/4" o.d.  stock exhaust so you would need 1 7/8" i.d. for a nice fit
The cherrybomb that is 1 7/8" inlet 1 3/4" outlet has  an 11 degree bend at the outlet and inlets.  Will this cause a big problem.  Is the cherrybomb fairly simple to install?  I live in an apartment, so I am limited to simple projects only.
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline olija
  • 770
    • Check out my cardomain
« Reply #18 on: March 07, 2007, 10:23:19 PM »
I'd also like to know as I will most likely be buying on Friday.
Offline echojeff
  • 414
  • Lo que sea
« Reply #19 on: March 08, 2007, 08:19:23 PM »
This one looks tough.... Is it worth the extra money?
http://store.summitracing.com/egnsearch.asp?N=400238+320931+115&autoview=sku
« Last Edit: March 08, 2007, 08:22:30 PM by echojeff »
95 Kick 4dr JLX.
Offline jzap
  • 515
« Reply #20 on: March 08, 2007, 08:25:07 PM »
Quote from: sidekickmuddog link=topic=16279.msg143714#msg143714
If I recall correctly, the offset is there to compensate for the fact that most stock mufflers have the inlet to one side and the outlet to the other.  In other words rotate the picture slightly so the inlet and outlet are horizontal.  It  should line up straight with the pipe going into the muffler and the outlet pipe should also be horizontal and line up with the tailpipe.
Look at your stock muffler.  If it has this type of configuration, it should work.  Hold the Cherrybomb up to it and you can tell if it is going to work without having to bend a new tailpipe.
                                    l-------------------l
                                    l   Muffler              l=== outlet
                   Inlet      ===l                          l
It shouldn't be too difficult.  If your muffler is more than 14 inches diagonally from the inlet to the outlet, you may have to cut out some of your exhaust pipe.  Ideally it is just a matter of a couple clamps and maybe a hanger.  At worst, everything's rusted into a solid mass and crumbles to pieces when you start trying to take it apart.   It's a good Saturday afternoon project.
« Last Edit: March 08, 2007, 08:47:33 PM by jzap »
Jim Z.
66 Apache camper
