Strength of stock tow loops
  • 22 Replies
  • 3447 Views
Offline olija
  • 770
    • Check out my cardomain
« on: March 01, 2007, 10:16:00 PM »
How strong are these things? They don't look super tough but looks can be decieving...anybody got any convincing stories or videos?
Offline kirknd4spd
  • 333
Re: Strength of stock tow loops
« Reply #1 on: March 02, 2007, 12:31:06 AM »
i used my kick to pull some trees around using a cable and the tow loops, when i was logging. the lack of power is what stopped me. well, that and a slipping transmission.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #2 on: March 02, 2007, 05:14:01 AM »
They are fairly strong, for what they are.. I wouldn't want to winch up a killer rock face with them, but I have towed my kick, and several other out of some pretty deep muck with them.
My opinion is, don't use them if a failure would send you careening down a hill.  Use them at your own risk, pulling out of mud, etc....
Offline costa 05
  • 206
« Reply #3 on: March 02, 2007, 05:22:33 AM »
They are ok to pull from but I wouldn't snatch with it because you'll rip them right off :P :P
when in doubt gas it!!
Offline bzzr2
  • 1011
« Reply #4 on: March 02, 2007, 06:24:06 AM »
i've used them to snatch and mine are still holding  :o, but somebody tried to snatch me out of a nice mud hole with a 4runner and i didn't move and the rear loop looks slightly bent.  i agree with quaddawg's thoughts on this.
09 taco reg cab short box 4x4
Offline westvilleguy
  • 53
« Reply #5 on: March 02, 2007, 06:45:08 AM »
i went into a mud hole with my 89 tracker hit a rock broke my frame and was hung up good on the rock my old man came out with his dakota had to hook the chain onto the front one cause the back was rotted off and pull from the back cause he couldnt pull it from the front he had to really come onto it to get the tracker out and the loop held up and this tracker is a rust bucket and the frame is pretty rotten i'd say they are fairly strong
89 chev tracker 4x4 tintop
91 gmc tracker 4x4 tintop
93 geo tracker 4x4 tin top
94 geo tracker 4x4 hard and soft top
Offline mntracker
  • 314
  • MORNEAU MVP
« Reply #6 on: March 02, 2007, 12:56:59 PM »
I have used mine to pull people stuck in the snow now twice, a Malibu and a Windstar, no problems
Offline wezzlegod
  • 227
  • under construction crowler
« Reply #7 on: March 02, 2007, 07:49:04 PM »
i pulled a Oldsmobile with no tires around my yard to get it into a position to wench it onto a trailer. also pulled a new Suzuki full size suv im not sure what it was off a rock he was trying to wheel it and the 4 wheel drive was not working
« Reply #8 on: March 03, 2007, 07:34:47 AM »
Mine have taken some abuse. A Samuarai snatched me out of axle deep sand once. He was really flooring his motor and I did think that I might lose the tow loop but it held. No sign of damage at all
Offline lowrezolution
  • 292
  • "Get bent!"
« Reply #9 on: March 03, 2007, 03:26:03 PM »
I have an 01, those hoops are plenty strong!
I've yanked out a full size x-cab gmc, x-cab dodge(teetering on a pine tree) and way too numerous jeeps (  ;D ). The rear one has bent out a little, the front hasn't budged.
my 2 cents
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #10 on: March 04, 2007, 07:16:14 AM »
This loops are just sh*t...
I tore off both front/rear loops on my 94 4 doors sidekick and the rear one on my 02 GV...
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline wibornz
  • 55
  • 5 atvs and now a tracker
« Reply #11 on: March 04, 2007, 10:04:44 AM »
I pulled the front one off.  I thought I was weak.
Offline BigPig
  • 276
« Reply #12 on: March 04, 2007, 10:08:00 AM »
If you pulled it off I'd say you're pretty darn strong!  ;D
'89 Sidekick w/ 4.5" of lift.
Offline ROSS
  • 1412
« Reply #13 on: March 04, 2007, 10:53:27 AM »
aren't those loops made for shipping tie downs??
Offline mntracker
  • 314
  • MORNEAU MVP
« Reply #14 on: March 04, 2007, 10:54:51 AM »
Fredo
You're trying too hard  ;D
