Has anyone put a XL7 rear axle in a GV
  • 26 Replies
  • 6586 Views
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
Re: Has anyone put a XL7 rear axle in a GV
« Reply #15 on: March 04, 2007, 07:55:31 AM »
The panhard bar on the XL7 is different than the GV's so if you use the GV's panhard the axle sits just slightly off center.  It's a small amount though, the "thought" amount is like 3/4".
The panhards are identical lengths, but the mounting points are slightly off.
XL-7 front coils
1.5" rear coil spacers
Offline binkie
  • 46
« Reply #16 on: March 04, 2007, 08:11:21 AM »
Does the front XL7 diff gears bolt into the Grand Vitara?
Marc
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #17 on: March 04, 2007, 07:26:54 PM »
Marc
Yes they are the same 7 inch ring and pinion that suzuki has used for years. Im not sure if the whole housing is interchangeable.
Mike
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #18 on: March 04, 2007, 07:33:33 PM »
A guy from Québec(ZR2 on the forum) fit kick 5.12 in a vitara diff. So you probably fit them in a GV diff.
Larger R&P = larger casing = less ground clearance.
Why don't trying a dana 44? you can put 5.13 in this and you have more locker option.
Fredo
On this build I would like to keep it pure suzuki. I want the stonger rear end as I plan to put some long highway miles on inbetween some nasty 4 wheeling. I realize In going to have to pull back the reigns a little but If I can build it strong enough out of the box, I wont have to completely change my driving style.
Mike
Offline gv1600
  • 83
« Reply #19 on: May 29, 2007, 11:33:47 AM »
Hi all,
what are the differences between the XL-7 rear axle and a GV rear axle ?
As i know, the XL7 has 28 axle splines and 8'' (or more) ring gear.
The GV has 26 rear and 7,5'' ring gear, correct?
Except those differences , are there are any others like .....  :
1. XL7 rear axle shafts are longer/wider than the GV axle shafts.
2.The couplers in the rear diff except that they are 28 slpines , how big they look?
3.Does XL-7 looks excactly the same in the rear brakes (except the brake line system), for example its uses 4 bolts for the axle shaft (maybe i,m wrong here) ?
4.does the XL-7 uses the same rims as any GV or they are more/less backspaced?
which means maybe a wider (possible) // shorter (dont think so)  rear axle than GV's ?
5.What is the diameter of the XL7 axle shaft?  same 27.4 as the GV's or a bit more?
Finally, i want to fit some XL-7 rear axle shafts with their 28 slpine couplers to my GV rear axle.... Cool   because i,m gona put a locker that it would be built from zero, so i may have enough space to fit the couplers if they re much bigger than GV's. ?
Is that possible ?
or do i need to swap the whole rear XL7 ?
Any help would be great, cause there isn't much time left,
Thank ya all !
PS: i 've posted that in the XL7 section too.
Suzuki GV Calmini 2,5'' - Full Steel V6 Frond Diff - 205/80/16 KL71 -
4.24 t-case - T-Max 6500 - VTTR Snorkel - ProTrack Air-Lockers F/R
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #20 on: May 29, 2007, 12:10:37 PM »
I never opened my axle housing up at all, just transferred it entirely from truck to truck, so I can't help with any of your internal detail questions.
The brake line system is pretty much identical, down to the last fitting.  I went from non-ABS to ABS, so there was tiny difference for me, but it was more just a matter of having a couple pieces left unused than anything.  There was no fabbing or trips to the parts store.
The axle housing/flanges/drums/shoes are seriously super-sized compared to the Vitara.
Same 16" rims, I'm almost certain.  If the XL-7's axle was wider, it wasn't by much.  I don't notice any difference at all (except for that bit about mine being slightly offset to the driver's side....still....).
XL-7 front coils
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #21 on: May 29, 2007, 12:17:30 PM »
Marc
The XL-7's front axle shafts are larger diameter than my Tracker's were (not sure about V6 GVs), but the entire front housing bolted right in.  Lots easier to swap the whole assembly than to swap gears.
XL-7 front coils
Offline gv1600
  • 83
« Reply #22 on: May 29, 2007, 12:24:26 PM »
Hi beercheck,
i dont mind about the rear brake system cause i,m gonna use my axle if everything is fine finally.
Offset to the driver's side?
Are you sure? got any picks yet to see that please.
If thats true, there must be a longer and a shorter rear axle , right?
If its the same lengh we will do a great start!!
let me know if you have some news please,
Thank you!
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #23 on: May 29, 2007, 12:41:13 PM »
Um...yeah....I'd say I'm sure.  But no, it doesn't mean that the axles are different lengths.  It means the XL-7's frame was slightly wider at the rear axle than my 2-door's was (or at least the Panhard bar mount on it was slightly more outboard, relatively), yet the Panhard bar was the same length, so the panhard mount on the axle housing was in a different location (slightly more inboard, relatively).  When I mounted that axle under my Tracker, with its slightly more inboard frame-side Panhard mount, the axle was located away a little bit to accommodate the same length Panhard bar.
All that said, it still doesn't answer your questions about axle shaft lengths.  I wouldn't be surprised if there was a difference in shaft length between the two.  Or not.  Sorry.
XL-7 front coils
Offline gv1600
  • 83
« Reply #24 on: May 29, 2007, 12:55:29 PM »
Notice that i wont be surpriced either if there is a difference between shafts length. 8)
I,m trying to find out and if there is a difference .....i won't start nothing.
But thanks for answering to me and i hope that there might be a guy who will give me the explenation i need ;)
« Reply #25 on: June 04, 2007, 12:55:25 PM »
I don't believe they are the same.  I'm the one who took the pic of a Sammy, Kick 12-bolt and XL7 pig. side-by-side, that floats till this day around the net.  There was a significant difference in the distance between sidegears from the 12-bolt to the XL.  Goes to figure since the diff is so friggin big compared to the 12-bolt.  So it would lent to reason that the shafts are shorter to accomdate the wider diffs.
I really wish that wasn't true, and that XL sidegears would fit in a 12-bolt carrier, but I don't think they will.  If so, the the XLs shafts could be an upgrade for the GV.
*dreaming*
Offline gv1600
  • 83
« Reply #26 on: June 05, 2007, 12:34:40 PM »
Hi Yankee-Tim,
i wish they fit just fine in the GV axle, but i don't know whats going on for sure.
Let me have some free time and i think i ll find out.
And yes...... if they fit they will be a very good upgrade for GV's.
