2000 4 Door Tracker Tire size
  • 1380 Views
Offline zbadboy69
  • 39
  • Freedom Isn't Free
« on: February 16, 2007, 06:13:55 PM »
I have a new set of 235 75R 15 Tires from my 91 two door Kick.  They only rubbed a little bit in the front when I had the steering wheel turned all the way.  Will these work on my tracker?  I have searched this and I get conflicting info.  Some say it only rubs in the front like it did on my 91 and others say it will rub in the back.  The rubbing in the back is what concerns me because that would mean it would be rubbing all the time.  Any help is appreciated.
Jeff
2001 4X4 Chevy Tracker Four Door 2.0 5 Speed
Offline lowrezolution
  • 292
  • "Get bent!"
Re: 2000 4 Door Tracker Tire size
« Reply #1 on: February 17, 2007, 06:41:01 AM »
My stock tires rubbed on the drivers side at full lock to the left!!
When I went to 235/75's it didn't get any worse.
Jam some tire under that thing! ;)
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline zbadboy69
  • 39
« Reply #2 on: February 17, 2007, 09:46:16 AM »
Thanks I'll look at swapping tires and rims in the next couple of weeks.  Better yet I will just switch the rims and tires and see how they fit and decide on whcich rims I want to use.
Jeff
Offline benzr2
  • 72
« Reply #3 on: February 17, 2007, 11:55:36 AM »
I just installed 235/75/15s and I have no rub issues at all. Just tire howl but you get what you pay for. The handling is way better than stock
2001 Tracker ZR2 235/75/15 ATs       1987 Samurai Tin Top     New Project!!
