clutch question
  • 1135 Views
Offline jaybyrd92
  • 30
  • 1992 Suzuki Samurai JL
clutch question
« on: February 12, 2007, 11:39:35 AM »
I have recently bought a clutch kit for my samurai. It has the clutch,pressure plate, throw out bearing and an alignment tool.
 On some kits there is also a pilot bearing. Is this a part I will need? if so why didn't it come in the kit I bought? And why wasn't it on the clutch I took out?
Never use money to measure wealth.
Offline 1badzuk
  • 96
Re: clutch question
« Reply #1 on: February 12, 2007, 12:11:40 PM »
the pilot bearing is in the flywheel. and some kits come with it and some dont. a cheap ones only about $5.00 If your changing the clutch i would resuface the flywheel and pop out the old bearing and put a new one in so it wont need to be doen and no problems its up to you. hope that helped a lil
87 sammy 33's sometimes on 35s hole lot of extras 4 link arb lockers built tcase and tranny 1.6 dual weber carbs racing seats snorkle and so on.........ALOT MORE..........
Offline sklope
  • 135
  • BUSHWACKER
Re: clutch question
« Reply #2 on: February 12, 2007, 05:52:38 PM »
Yep, you may as well change out the pilot bearing while your there! Cheap, inexpensive insurance. One thing that 1badzuk mentioned is "get the flywheel resurfaced". Do that too! That insures that everything is taken care of while your working on that area!
* '96 Tracker
* 2" Sky body lift
* 235/75/15 M/T's
* Custom front and back bumpers
* Durabak exterior coating (bed liner) * '07 chevy silverado "wail tail" tailgate cover (custom cut to fit)
Offline jaybyrd92
  • 30
Re: clutch question
« Reply #3 on: February 13, 2007, 06:22:34 AM »
Thanks guys! I'll go ahead and get the bearing and have the flywheel resurfaced.
Offline costa 05
  • 206
Re: clutch question
« Reply #4 on: February 15, 2007, 02:37:48 PM »
Buy some rubbing alchohol and use it on the flywheel to remove any oil on it. (finger prints) before you put it together.
when in doubt gas it!!
