squeeeeeking
  • 1217 Views
Offline sidekick101
  • 128
  • best site on the net
squeeeeeking
« on: February 07, 2007, 05:33:53 PM »
every bump i hit its all my fornt end does. is it just the spings up front, the a rams, what is it. please help. can't take it anymore. oh and its not the little road bumps its logs, rocks and speed bumps lol. hope that helps a bit thanx
nick
1993 sidekick JX, 2 dr, soft top, automatic,
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
Re: squeeeeeking
« Reply #1 on: February 09, 2007, 03:08:38 PM »
It could be your ball joints.. Mine did the samething, and then I changed the balljoints and the squeeking went away.  Hope this helps.
Sunrunner GT, Gold Trim Level
Offline geeeeoooo
  • 246
  • mmmdrop
    • my myspace page
Re: squeeeeeking
« Reply #2 on: February 10, 2007, 08:35:25 AM »
my 95 tracker also had the squeeking issue with the front end, but my balljoints were good, so i made a lil pinhole with a grease needle on the end of a greaqse gun, and pumped the boots all up with grease, most other vehicles have grease zerks made right onto them....not our vehicles.....i also lubed my tie rods with the needle, and all squeeking went away after driving it a hour or so....just had to let the grease work into the joint
Offline spazzz
  • 21
Re: squeeeeeking
« Reply #3 on: February 15, 2007, 02:41:13 AM »
My squeeking started when it got bitter cold.. it was ok when I come to work and went to the underground parking.. on my way out in the morning, it's fine.. no squeek..after sitting out in the cold all day and on my way back to work, it starts again...I brought my can of silicon spray lube and sprayed my rubber bushings for my front sway bars..seems to be gone now for the last 2 days..
***Build it ! Break it !! Fix it !!! Build It Better !!!***
94 Sunrunner/4" body lift/3" suspension/33x12.5x15 D/T's /10.5 blue chrome wheels/cold air/winch/custom dents and scratches
