Heater fan
  • 1422 Views
Offline olefafl
  • 46
Heater fan
« on: February 02, 2007, 07:41:11 PM »
Can the heater fan be replaced with a different one that moves more air?
On some Jeeps you can install a Chevy blower without changing anything, it just bolts in.  But moves more air.
Offline museboy07
  • 641
Re: Heater fan
« Reply #1 on: February 02, 2007, 09:35:39 PM »
Im looking for the same thing..my heater is way too loud and does not blow fast at all...any help would be great
Offline Uncivilized
  • 1469
    • Car Domain
Re: Heater fan
« Reply #2 on: February 03, 2007, 05:36:07 AM »
Haha, I thought it was only mine!!  I was thinking maybe it was just wearing out, and was going to buy a new one from the dealer. BTW- look under your dash and make sure all your duct work is connected, I had a lose one, and it was leaking air, I fixed it and it made it a little better, but it still sux.
Offline takai
  • 907
Re: Heater fan
« Reply #3 on: February 03, 2007, 08:06:41 AM »
I have been looking for an older snowcat heater. My friend mounted one in his jeep and the that rig stays VERY warm in the winter.
'Cause, I am to misbehave.
Re: Heater fan
« Reply #4 on: February 03, 2007, 10:10:24 AM »
If your a Sammy, dont' forget to clean the heater first.  The heater core gets covered with leaves and such that come in through the air vents.  :)
Offline daddyizzle
  • 728
  • Colorado is still my home!!
Re: Heater fan
« Reply #5 on: February 03, 2007, 11:17:23 AM »
I cleaned mine out and it helped. My problem, is when I have it on defrost with hot air blowing on the windshield, I get cold air flowing through the circle vents. I don't know if that is normal or maybe a door in the system is not sealing right. I'm sure it is coming from the outside somewhere. Just haven't had time to investigate. Luckily I'm in a tintop so it helps hold some heat in.
-Adam
Offline olefafl
  • 46
Re: Heater fan
« Reply #6 on: February 03, 2007, 04:12:12 PM »
I cleaned the heater, it had a mouse nest in most of it.
I also get cold air out of the circle vents, but I filled them with papertowels for now.  I am going to pull the dash out and close off the circle vents so all the air has to go into the heater core.
I was just hoping for a bolt in fan that would move some air.
