scary at higher speeds
  • 1609 Views
Offline hemiwin
  • 15
« on: February 01, 2007, 07:54:44 PM »
I have a 1990 sammy with a 8" SPOA and 32" tires.   At road speeds(35mph+), it wanders all over the place and is hard to keep on the road.
Will a steering stabilizer help? How about the Old Man Emu that bolts on in the stock location?
Or should I get a trailMaster dual stabilizer?
Any other suggestions??                     THANKS
Offline costa 05
  • 206
Re: scary at higher speeds
« Reply #1 on: February 01, 2007, 08:10:00 PM »
SOUNDS LIKE YOU HAVE BUMP STEER, IN SHORT YOU HAVE TO REDUCE THE ANGLE OF YOUR STEERING  ARM
when in doubt gas it!!
Offline okezuki
  • 51
« Reply #2 on: February 01, 2007, 08:25:09 PM »
When you did the spoa, did you keep your castor angle correct?
87,33`s,6-1 t-case,d.c.drive shafts,locked,m/l with cj`s,dt8000`s,& the will to BEAT THE SNOT OUT OF IT!
Offline Amilla
  • 1076
« Reply #3 on: February 02, 2007, 08:51:33 AM »
Do you have Hi-steer?  If not you should try that, full stage 2 hi steer is awsome, it gets rid of mostly everything and makes the turning a lot nicer.  The Z-link bar still has bump steer and i think it steers differently.
I have never delt with the dual stabilizer befor, just the OME one and it works pretty dam good, i have no complaints.
well i hope that helps out a bit
-Amilla
Offline hemiwin
  • 15
« Reply #4 on: February 02, 2007, 09:29:32 AM »
Thanks guys, it has the Over The Top steering.
Rocky road as well as you guys said to get an alignment and have the castor checked.
That is what I will do .
THANKS
« Reply #5 on: February 02, 2007, 02:34:30 PM »
pic's would be nice!
Offline hemiwin
  • 15
« Reply #6 on: February 02, 2007, 06:54:36 PM »
How do I post pics?
It would be nice to post some so you guys could tell me if anything looks wrong from looking at them.
« Reply #7 on: February 02, 2007, 11:58:23 PM »
How do I post pics?
well maybe if ya read the second posting
Welcome to the ZUKIWORLD BBS Forum + HOW TO Post pictures
It will instuct you on how to post them there pics.
