T.T. power steering install
  • 1159 Views
Offline RGERBER
  • 81
« on: January 28, 2007, 01:30:36 PM »
Well,
As soon has I get the pitman arm puller I will be done, all I lack is switching pitman arms and installing the radiator.
The pump is in and bolted, the bracket bolt spacers are welded in place as required. The is pump reservoir has been located and bolted with all hoses cut to size, and securely hooked up, the pulley is bolted in place - with belt on- and in great alignment.
It's all painted  - Its done except to switch the the pitman arm, add fluid and install radiator.
94 SUZUKI SAMURAI / 1.6 8 VALVE TRACKER MOTOR.
Offline takai
  • 907
Re: T.T. power steering install
« Reply #1 on: January 28, 2007, 03:00:44 PM »
Pics?
'Cause, I am to misbehave.
Offline RGERBER
  • 81
« Reply #2 on: January 29, 2007, 06:29:17 PM »
I have pics, but dont know how to post, i can email
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #3 on: January 29, 2007, 07:05:29 PM »
From the intro/readme post:
Posting Pictures / Attaching Files:
To attach a file to your post, click on the "additional options..." link located directly below the text editing box that you are typing words in. Click on the "browse" button to locate the file or picture you want to upload. Choose file. Now, when you press save to post, the software will automatically upload the file and display that to all.
XL-7 front coils
1.5" rear coil spacers
