jeep tj coil spacers?
museboy07
641
January 22, 2007, 08:26:04 PM »
i was readin around the web and i found that you can use 2 inch jeep tj coil spacers for my 94 track if i cut the center hole to 2.25inch. there alot cheaper then regular spacers for my rig. can this be done or are these ppl crazy?
derekj
784
i'm the canadian guy eh?
Re: jeep tj coil spacers?
January 22, 2007, 11:29:08 PM »
sky manufacturing sells their coil spacers for $80 for a set of 4 and digger sells his here on the site also. then you dont have to mess around with drilling the other ones.
derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
32" TSL's and some other stuff I did And now with a Lockrite!
www.cardomain.com/memberpage/783382
Uncivilized
1469
January 23, 2007, 04:54:23 AM »
I did it before, but it's not necessary now with the above mentioned. The inside hole needs to be
2.5"
not 2.25".
bzzr2
1011
3
Reply #3 on:
January 23, 2007, 08:43:29 AM »
i have a heep spacer all chopped down to size in addition to my jdmcrx spacers in the back, they fit well once shaped to size which was done before i received them from another member on the board.
09 taco reg cab short box 4x4
2K-Otic
16
Reply #4 on:
January 23, 2007, 09:42:44 AM »
http://bbs.zuwharrie.com/content/topic,52385.0.html
Read the comment from RockMolester.
My personal feelings about the TJ spacers is if you're going through the trouble of reaming out the center hole, why not just go one step further and make your own? In that same thread you will find a post that I put up that describes the process.
That's my 2 cents
92 Tracker
2" Home made coil spring spacers
3" Home made body lift
3" Cold air intake
31x10.5 Mud Kings on 15x8 spoke wheels
