Detroit ez locker Making noise
  • 1867 Views
Offline TysonS
  • 383
  • www.funinbc.com
« on: January 19, 2007, 02:59:28 PM »
I got a detroit ez locker from a sami in the rear of my sidekick using the samuri side gears. Now im getting problems.... When I drive it around it will be fine most of the time and then I will push the clutch in and then let it out it will makes a pop nosie and the drivers side tires doesn't spin, it will keep makeing that nosie and usually it will lock in but that is after alot of pops. Sounds like a spring poping out. Sometimes it will just pop and never lock in and sometimes it will lock in a work fine. What could be the problem? I havn't changed the gear oil since I put in it 4 months ago, could it be that? Or maybe the locker isn't shimmed right
thanks
Offline Quaddawg
  • 1622
    • My Ebay Store
Re: Detroit ez locker Making noise
« Reply #1 on: January 19, 2007, 03:12:55 PM »
Yeah, sounds like it isn't set up tight enough, that would be my first place to look.
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #2 on: January 19, 2007, 03:13:53 PM »
thanks for the quick reply, looks like im going to have to pull it all out and give it to my buddy.
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #3 on: January 19, 2007, 03:20:04 PM »
I wasn't aware that the locker from the rear of a sammy would be big enough for the carrier on the rear of Kick...
Did it used to work ok??
I have heard of using the rear locker for a sammy in the front of a, since they are virtually the same, but not in the rear..
guess I learn something every day.....
I would like to see how it is set up though.
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #4 on: January 19, 2007, 03:28:20 PM »
well, when I first put it in it was working fine, ever since we started getting snow it has been acting weird.  But im not to sure how it was put in, all I know is that the installer had to use the samuri sidegears to fit the locker properly because the stock sidekick ones were different, im sure that he just installed it a little too loose and now something wore down a bit from use and need another shim or two.   Hopfully a quick fix, i wanna go wheelin on the 28th
Offline Quaddawg
  • 1622
    • My Ebay Store
« Reply #5 on: January 19, 2007, 03:31:42 PM »
Keep us posted...
I am curious to see how it holds up, and if it was just a spacing problem
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #6 on: January 19, 2007, 03:51:48 PM »
i sure hope it is, just got it not to long ago
Offline TysonS
  • 383
  • www.funinbc.com
« Reply #7 on: January 20, 2007, 12:55:09 PM »
well, i bought the locker used for cheap and most people are saying that it will need new springs?   does this sounds right? makes sence to me.
anyone know where i can get new springs FAST?
