Did anybody install Eagle Alloy wheels?
  • 11 Replies
  • 2942 Views
Offline Joel
  • 29
    • Abitibi-Temiscamingue Racing
« on: January 17, 2007, 05:27:56 AM »
I'm looking to install Eagle Alloy 055 wheel.
PN: 0550-7757
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=22
They look good and they are availaible in 16X7 size.
I'm pretty sure they fit on my Vitara, but a supplier (who has very good price) said me they will not fit, because the Vitara is not in his listing.  ::)
Joel
Suzuki Vitara 2004 V6
Hyundai Genesis Coupe 2.0T GT 2010
Offline TysonS
  • 383
  • www.funinbc.com
Re: Did anybody install Eagle Alloy wheels?
« Reply #1 on: January 17, 2007, 08:24:48 AM »
If they are 5 x 5.5 and have a 4" hole in the cetner for the hub to go threw they should fit
« Reply #2 on: January 17, 2007, 10:11:26 AM »
I run a 15x10 that looks just like those on my samurai, I would have them pull off one of your front rims and bolt on one of theirs to make sure it clears the caliper, if so go for it.
Offline Joel
  • 29
« Reply #3 on: January 17, 2007, 10:35:40 AM »
4" ?
I think is 4,25" (108mm)  ???
It's the measure I've taken on my stock wheel and measure listed here:
http://adaptitusa.com/referencebook.htm
Joel
« Reply #4 on: January 18, 2007, 05:00:49 AM »
I have a set of those, they were quite common over here, sold by Suzuki as an optional extra with the WideboyFatboy kits. I have the 8x15s and they are VERY heavy, I put steels on instead, saves a lot of weight.
« Reply #5 on: January 18, 2007, 07:16:26 AM »
If it's a V6 GV, prolly not.  Very few options for the GVs.  Calipers are big, needs a JJ code for the rims.
Offline PHX96TRACK
  • 90
« Reply #6 on: January 18, 2007, 03:29:51 PM »
Whoa heavier than steel?  :o These alloys are heavier? By how much? ???
96 4dr Tracker - 30x9.5s on 1-3/4" spacer lift. 2.25" Cat-back with Turbo exhaust.
DD is a Stock 93 Toyota Paseo- great car
2003 Toyota Matrix XRS- Family car
« Reply #7 on: January 19, 2007, 05:02:12 AM »
Yeah, ally is 1/3 the weight of steel but steel rims are usually pressed from sheet steel. Those alloys are a very thick casting. Theres an awful lot more than 3 times the amount of metal so it works out a fair bit heavier.
Offline Joel
  • 29
« Reply #8 on: January 22, 2007, 05:30:33 PM »
With all contracdictive informations I've received from many suppliers (wheels will fit, whells will not fit, wheels are discontinued  ::)  ), I will not take any chance.
I've ordered 16X7 steel wheels this morning from a local tire dealer.
Those wheels are sold to Vitara, GV and XL7 owners to install winter tires.
They look at that:
Joel
« Reply #9 on: January 22, 2007, 06:09:38 PM »
They look at that:
I'd like to find a set of those.
« Reply #10 on: January 23, 2007, 05:12:46 AM »
Over here those wheels are fitted as stock to most GVs. You get a lot of owners fitting alloys from new and the steels can sometimes be had quite cheaply from the dealers.
Offline Joel
  • 29
« Reply #11 on: January 23, 2007, 02:51:07 PM »
They look at that:
You can look here, but they are a little bit expensive on this site:
http://shop.wheelsrims.net/search.html?make=suzuki&model=grand_vitara&year=2000&part_type=
I've paid 88,50$ (canadian dollars) for mines.
« Last Edit: January 23, 2007, 02:53:27 PM by Joel »
Joel
