how do you score on articulation ramp
  • 2017 Views
Offline mlovetripp0
  • 204
  • do more with less
« on: January 01, 2007, 10:44:30 PM »
what if the formula for points on a rti ramp or can shear height be figured in?
i get 36" going up and 35" going backward ,up this concrete ramp.
i found this ,
can it be used in my case , 87" wb with 38" tires
87 sammi
Re: how do you score on articulation ramp
« Reply #1 on: January 02, 2007, 07:01:12 AM »
Wheelbase (hub to hub) devided by horizontal length traveled up the ramp= Number
then multiply that Number by 1000 and that will give you your RTI.
For what ever degree inclien you are on at the loadingh dock (10-15 deg???) you scored well over 1000
Offline mlovetripp0
  • 204
  • do more with less
« Reply #2 on: January 02, 2007, 04:05:37 PM »
thx i needed the clarification
87 sammi
Offline stock93tracker
  • 309
« Reply #3 on: January 02, 2007, 04:32:16 PM »
running shockless it looks like???    ???
93 Geo Tracker
-2" Lift
Offline mlovetripp0
  • 204
  • do more with less
« Reply #4 on: January 02, 2007, 05:11:29 PM »
we need measurements to see how far the shocks need to extend and contract.
87 sammi
Offline Amilla
  • 1076
« Reply #5 on: January 02, 2007, 05:13:40 PM »
Just gotta make sure to drive extra slow  ;D
Do you get any drive line binding, or bad vibs from the rear? I belive those are toy axles but i could be wrong.
Amilla
Offline mlovetripp0
  • 204
  • do more with less
« Reply #6 on: January 02, 2007, 05:54:29 PM »
Amilla
i kept her under 40mph she was a little bouncy
there was a little shake from the rear ,but snapping the rear driveshaft down at the river earlier fixed it.yeh are you sure on the toy axls?
« Last Edit: January 02, 2007, 06:00:36 PM by mlovetripp0 »
87 sammi
  • 309
« Reply #7 on: January 03, 2007, 08:04:19 AM »
ahh, I see..  Try running it on the highway at 55, see what happens and report back..  IM curious..
93 Geo Tracker
-2" Lift
