misfiring and power loss please help
  • 806 Views
Offline thorlof
« on: December 27, 2006, 08:30:43 PM »
ok here is the set up
87 zuk 1600cc with 1300head a class 1 cam  and then a Weber
every thing else is stock
its cold about 35 degrees fahrenheit out
the zuk starts up and runs fine
4to5 miles into the drive and the motor is all warmed up
and it starts to misfiring and then starts backfiring at around 4000 rpm
some times if i stop the car shut it off and re start a few seconds later it runs fine
or i can knock on the side of the distributor housing and it clears up
im thinking the electronics in the distribute are going out???
any suggestions or thoughts...
help cuz it getting worse i think
« Last Edit: December 30, 2006, 07:48:01 AM by thorlof »
Re: misfiring and power loss
« Reply #1 on: December 27, 2006, 10:08:24 PM »
I would check for a broken wire inside, a loose ground, and also clean the plug to the dist, and look for traces.
