pops out of 4wd
  • 9 Replies
  • 2240 Views
Offline sir lance
  • 342
  • I love my XL-7
pops out of 4wd
« on: December 09, 2006, 07:40:01 PM »
like the sub says, 4 hi or 4 low flat ground,or off road, wont stay in 4wd......
it will stay in for alittle bit, then without warning will just pop out......
any ideas?
the first owner said he never used 4wd, so i cant see it being warn out.....
its a 1999 automatic.....
thanks
-Lance
Offline 1badzuk
  • 96
Re: pops out of 4wd
« Reply #1 on: December 09, 2006, 11:45:52 PM »
is it stock any lift or body lift???
87 sammy 33's sometimes on 35s hole lot of extras 4 link arb lockers built tcase and tranny 1.6 dual weber carbs racing seats snorkle and so on.........ALOT MORE..........
Offline sir lance
  • 342
  • I love my XL-7
Re: pops out of 4wd
« Reply #2 on: December 10, 2006, 08:38:50 AM »
its 2" body  and 3" susp, but it was doing this in its stock form when i bought it.......
that was my first thought too
but that would just be to easy LOL
Offline 1badzuk
  • 96
Re: pops out of 4wd
« Reply #3 on: December 10, 2006, 05:37:19 PM »
mine was poping out the other night but i didnt have the hubs all the way in 4x4 dont know what that matterd but it did    sorry im not sure but ill try to ask around
Offline sir lance
  • 342
  • I love my XL-7
Re: pops out of 4wd
« Reply #4 on: December 10, 2006, 10:56:53 PM »
its strange, its not like the shifter is loose/sloppy, it feels normal when you take the t-case in and out yourself, witch would sugest that the interlock pin (detent spring) whatever you want to call it, is in place......
Offline lowrezolution
  • 292
  • "Get bent!"
Re: pops out of 4wd
« Reply #5 on: February 13, 2007, 10:41:44 AM »
Now I'm having this issue too!
Of coarse we getting 16" of snow tonight and who would need 4x4 in that. ;)
It will only partial engage in high 4 and can't even budge it to slide into low 4!
I have to really push hard to keep it engaged, the neighbour said all four tires were spinning in the snow but as soon as I put any kind of excelerator down it pops out with a quick grinding clunk!
I've never seen this before!
Any suggestions?
2001 Tracker LWB
Boondox coil spacers and BDS springs 3.25" rear lift/3" front lift,3" body lift. 265/75/16 Durango Mud Terrains. (32")
Offline bzzr2
  • 1011
Re: pops out of 4wd
« Reply #6 on: February 13, 2007, 11:35:03 AM »
is your 4x4 indicator light staying on when it pops out?  mine flickers but haven't noticed any issue with the 4x4, may be completely unrelated.
09 taco reg cab short box 4x4
  • 292
  • "Get bent!"
Re: pops out of 4wd
« Reply #7 on: February 13, 2007, 12:13:19 PM »
The indicator stays on for the most part. It doesn't sound like its the axle disconnect system but definetly the t-case.
Could a vacuum leak cause this?
« Last Edit: February 13, 2007, 12:55:01 PM by lowrezolution »
2001 Tracker LWB
Offline IanL
  • 466
Re: pops out of 4wd
« Reply #8 on: February 14, 2007, 12:52:28 AM »
If the Transfer shifter is popping out, it's either worn parts, broken or weak locating spring or a disengaged circlip in the TC.
  • 292
  • "Get bent!"
Re: pops out of 4wd
« Reply #9 on: February 14, 2007, 03:24:37 PM »
Here's what I came across, water in the t-case!!
Took it inside a shop, dropped the fluid and found ice crystals, flushed and refilled and also blew out all the vacuum lines. Work properly now!
Received a tip from a heep guy on this.
Hope this may help someone else.
2001 Tracker LWB
