i checked the chiltons manual and it says the clutch is almost exactly the same between the trackers, sidekicks, sidekick sports, and sammis. check the flywheel for warpage, check for a warped clutch disc or damaged clutch damper hub, or check for a loose or damaged clutch pressure plate. or your synchronizers are worn or the synchronizer sliding sleeve is worn. also the gear engagement dogs may also be worn.
