weber 40 dcoe need help with carbs ANYONE know what fuel pressure?
  • 26 Replies
  • 8130 Views
Offline 1badzuk
  • 96
Re: weber 40 dcoe need help with carbs ANYONE know what fuel pressure?
« Reply #15 on: December 05, 2006, 06:41:40 PM »
what do you mean by single and double spring float?? i have dual 40 dcoe side drafts what fuel presure should they get??
87 sammy 33's sometimes on 35s hole lot of extras 4 link arb lockers built tcase and tranny 1.6 dual weber carbs racing seats snorkle and so on.........ALOT MORE..........
  • 6551
  • 64
« Reply #16 on: December 06, 2006, 08:21:55 AM »
1.5 to 2.0 psi.
Offline 1badzuk
  • 96
« Reply #17 on: December 06, 2006, 11:22:40 AM »
only 1.5 to 2.0 on a 1.6 8v with dual 40 dcoes?????????????
  • 6551
  • 64
« Reply #18 on: December 06, 2006, 01:40:08 PM »
Yes.
Offline 1badzuk
  • 96
« Reply #19 on: December 06, 2006, 02:57:22 PM »
ok cool ill go check it now.. also should i have the vacum advanced hooked from the distributor to the inktake or hows that go i think i  have it right. but im not sure it has a t fiting on it conecting it to the carb ,distributor, and the brake bootser thing
  • 6551
  • 64
« Reply #20 on: December 07, 2006, 09:08:46 AM »
Dude... READ the article that I posted a link to in this thread.
Offline 1badzuk
  • 96
« Reply #21 on: December 07, 2006, 10:32:59 AM »
dude thats a 1.3 zuk motor i have a 1.6 tracker motor im sure theres a difference thats what i m trying to find out if anyone out there has this setup and what there specs are.. thanks for the help though
  • 6551
  • 64
« Reply #22 on: December 07, 2006, 11:22:13 AM »
As long as you're sure there is a difference, I won't worry about it.  ;)
Did you read any of my posts? From earlier on in THIS thread Fundamentals are the same. I've had mikuni and weber sidedrafts on both 1.6 8-valves and 1.3 engines. That carburator set the the story was about came off of a 1.6 and was put on a high po 1.3 that Reynolds machine built for me. I had to up the main jets!
Offline 1badzuk
  • 96
« Reply #23 on: December 07, 2006, 11:39:51 AM »
it ran mint on my 1.3 when i put it on the 1.6 it wasent getting enough fuel so i went and got a lil more bigger main jets now i dont know whats goign on when i hit wot it doggs i guess im back to zero.. its getting enough fuel pressure and i got them pretty close without useing that tool which i just bought but waiting on it to get here..im thinking something got messed up when i swaped motors
Offline 1badzuk
  • 96
« Reply #24 on: December 07, 2006, 11:41:17 AM »
there is a difference but not that much dont know if it will affect anythign or not. 1.3 1300cc 1.6 1600cc at 5500 rpm theres a nice drop read the charts
Offline TrAkLsI
  • 61
« Reply #25 on: December 07, 2006, 09:02:08 PM »
1badzuk  post some pics of your carb set up  ;D  BTW where did you get your manifold?   thanks,
Offline 1badzuk
  • 96
« Reply #26 on: December 07, 2006, 09:25:23 PM »
it all came on the 1.3 when i bought it and i never had the stock stuff or i would just put it back on asap ok ill take some pics as soon as its daylight
