zuktoy update
  • 1772 Views
Offline wezzlegod
  • 227
  • under construction crowler
zuktoy update
« on: November 12, 2006, 04:24:44 PM »
ok i did some work on my zuktoy and decided to see if a toyota raidiator would fit into it. it did with a little cutting but no welding. i used the stock raidiator brackets cut down and drilled. hears a pix.
« Last Edit: November 12, 2006, 04:30:22 PM by wezzlegod »
Offline wezzlegod
  • 227
Re: zuktoy update
« Reply #1 on: November 12, 2006, 04:36:11 PM »
also i mocked up the trans and t casas the pix are ot that good but hear you go
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: zuktoy update
« Reply #2 on: November 12, 2006, 05:43:25 PM »
Sorry if I missed something but are you putting a toy engine trans.. is that still a trackick case? Im a little confused.
Mike
Offline Amilla
  • 1076
Re: zuktoy update
« Reply #3 on: November 13, 2006, 09:44:30 AM »
im not to sure what your plans are?
did we miss somthing?
lay down the info  :D
Re: zuktoy update
« Reply #4 on: November 13, 2006, 10:42:53 AM »
Offline Amilla
  • 1076
Re: zuktoy update
« Reply #5 on: November 13, 2006, 04:41:10 PM »
awsome, now i see the whole picture. Looks like everything is going along pretty well.
