fuel pump for 1.6 conversion
  • 1800 Views
Offline DRAGGINZUZU
  • 141
« on: November 10, 2006, 05:49:52 PM »
Do I just get a universal external fuel pump with 5 psi for a 1.6 with the 1.3 carb on it? who has the cheapest? part numbers??
Tony
Its not what you buy but what you build
 Tony
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: fuel pump for 1.6 conversion
« Reply #1 on: November 11, 2006, 06:42:24 PM »
Its been a while since I messed with any carb stuff but I do recall having to put a fuel pressure regulator on the system. I also had a hard time getting an electric fuel pump to be reliable after being restricted down to 5psi.
Mike
« Reply #2 on: November 12, 2006, 08:29:51 AM »
Mike
Do you mean regulating an EFI pump down to 5psi??
Pretty much any aftermarket 5psi pump should do the job.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #3 on: November 12, 2006, 05:31:23 PM »
Mike
All the aftermarket pumps I could find were 15psi+. Then I had to buy a regulator to get down to 5.
Mike
Offline DRAGGINZUZU
  • 141
« Reply #4 on: November 12, 2006, 07:38:39 PM »
RRO sells one for 39$ is that what I need?
Tony
 Tony
« Reply #5 on: November 13, 2006, 04:55:05 AM »
Tony
I don't see any details on their site. Something like this would do
http://rallynuts.com/motorsport/FACET_Fuel_Pumps_1861/Facet_Silver_Top_Road_Fuel_Pump_Kit_3233.asp
Offline aftermarket4x4
  • 145
  • ZUKIWORLD
« Reply #6 on: November 13, 2006, 05:57:20 AM »
The local Advanced Auto Parts stores around here have 5psi fuel pumps for $34.99 and they are right on the shelf. Try them first and if not Jegs and Summit have them pretty cheap as well.
Sean
