Inboarding rear coils???
  • 18 Replies
  • 2354 Views
Offline Chief
  • 678
  • Whaddya lookin at??
Re: Inboarding rear coils???
« Reply #15 on: January 18, 2005, 08:25:47 AM »
I was just trying to figure it out in my mine.  So "once again" I was trying to figure it out.
What shocks are you running?  Those are your first limiting factors.  Once you have long enof shocks to where your spring are loose then your springs are your limiting factor.
But,
I have a set of Ford F-150 4x4 shocks on mine.  Calimni 3" springs set to where their loose and I don't think I'd want any more drop.  I/we have a slip yoke, and any more drop and I'd be worried about the drive shaft coming out to far.
Flexing over rock and such would not be a problem, but hitting a jump at 20-30 mph and getting a little air, the whole rear end cycles down and ???
Also, I remember Mike stating once that at one time he had too much articulation in the rear for the front IFS.  It was unstable.
All good points, and reasons I'm keeping all the stock stuff around. Just trying something a little different. If it works, great! If it f***s up, just bolt everything back in the stock location.
W/ a 2" spacer, I've already maxed my rear end. If I got the XJ coils to work how I liked it, I would have had a 28" uncompressed shock maxed out.
Bent a sammi rear end w/ coils? Where you jumping it? and this is a tracker axle, figure they are different, since trackers come with coils stock.
« Last Edit: January 18, 2005, 08:27:21 AM by Chief »
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #16 on: January 18, 2005, 08:44:54 AM »
I'm all for trying things.
Good luck and let us know.
We've talked about the center diff. on this board.  I once cut up a rear axil to see how it would fit cented.  It was too big, even the motor lifted 4".  Still not a dead thought though.
32 MTR's Warn 8000i
« Reply #17 on: January 18, 2005, 09:04:35 AM »
Not my truck so I don't know how it was being driven. The Tracker axle is stronger but then again the Tracker is heavier too. The Tracker has coils as stock but moving them in leaves more of the axle unsupported. Might not be a problem at all, I just thought it was worth mentioning. It would be a bit of a downer to make everything replaceable and then trash the axle - be the sort of thing that happens to me  ::)
Offline Chief
  • 678
« Reply #18 on: January 18, 2005, 09:44:49 AM »
LOL true true. I got a yard with about 4-5 trackers sittin in it right now, so I can pick up rear axles realitivly cheap. Worse comes to worse, I'll steal the one out of my GF's tracker!  ;D
