spring over
  • 1163 Views
Offline DRAGGINZUZU
  • 141
spring over
« on: October 10, 2006, 10:04:00 AM »
Do I need to rotate the rear axle upward to match the driveshaft. Or do I make the pinion angle the same as the output on the transfer case? when I weld on my spring perches? and for the front I want the same pinion as factory to maintain the front geometry ?
Its not what you buy but what you build
 Tony
  • 6558
  • 64
Re: spring over
« Reply #1 on: October 10, 2006, 10:44:54 AM »
Don't rotate the rear end unless you plan on putting on a CV style driveshaft. Here's a nice article in the ARCHIVES that may help you...
http://www.zukiworld.com/month_050104/feature_trailtough_yjlift_install.htm
Offline Sami86
  • 41
Re: spring over
« Reply #2 on: October 10, 2006, 08:00:17 PM »
just dont do it 1 axle at a time....it look really funny.... trust me .... stock frontend and sprung over rear with 2" shackles is hella funny
1986 Samurai stock drivetrail, 2" shackle lift 30" tires..
