How are drive shaft angles with this centered set up? Are you get any bad vibes?George
My last score was 1180 on a 23 degree ramp with air pressure at 6 psi. That is the pressure I wheel at.
Mike,From what your say you have something like this? Just with wide mounting points.
Hi Mike, On those OME's do you have the top dropped to maximize travel? What happened with that longer Chevy strut you were working on awhile back?Dave
Not at Moab, you were running like 12 Ever figure out who pumped up your tires ?
am i missin somethin here, i thought this was about an axle not tires, and is there an inside joke about mikes tires?
Hi Mike last question what CV's are you running now?
Passengers side 92-95 Nissan Maxima. Just to be clear for the people who dont already know they are modified... I cut the ends and welded tracker ends on... they dont just bolt in. (long story)Mike
