Evil Seed:  9 Inch Anvil?
  • 143 Replies
  • 26179 Views
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Evil Seed:  9 Inch Anvil?
« Reply #105 on: January 21, 2005, 12:46:17 AM »
You know what makes me mad about all this is that no one sells this stuff.
Well, I believe that will change in March.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline blacknight
  • 987
    • Gonzookin
« Reply #106 on: January 21, 2005, 12:53:06 AM »
Don't tease me  ;)
George
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #107 on: January 21, 2005, 02:18:52 AM »
Don't tease me
No teasing - Kerry is doing the Tora Tora axles - he says production in March.
Bob
Offline blacknight
  • 987
    • Gonzookin
« Reply #108 on: January 21, 2005, 06:56:43 AM »
My only problem with this that I have an XL-7 no anvil for me  >:( unless I could talk some one into mod-ing one to fit.
George
Offline sidekicksrock
  • 416
  • Lil Suzys Dad
« Reply #109 on: January 21, 2005, 06:58:49 AM »
XL7 I thought your front end chunk and housing were already Steel?
Student of Now Master of Then
mudfkr
« Reply #110 on: January 21, 2005, 07:10:30 AM »
George
I don't think Tora axles (unless they are longer then stock ones ?) would work on a XL 7 even if you could get an Anvil in it. The G/V axles are longer by 38mm's over a stock 1600 axle then they have a different spline just to make things more complicated  ???
Offline blacknight
  • 987
    • Gonzookin
« Reply #111 on: January 21, 2005, 07:30:42 AM »
The size wouldn't be that big of a deal to work around.  But the splines I thought where the same?
George
mudfkr
« Reply #112 on: January 21, 2005, 07:48:36 AM »
Sorry I should have been more clear,
The spline on the end of the axle it self is different, the axle looks bigger in diameter until you pull the C/V boot off it then you notice it's shoulder down to near the size of the 1600 axle where it fits into the C/V but with much finer spline. The spline for the FWH's and 26 spline diff are the same.
The outer C/Vs are the same dimensions as mine and would work but the inner right would not be able to used (with a stock kick diff with 26 spline side gears) as it has the off set for the G/V air actuated diff, not that I'd need the right as I was looking at using these with the anvil.
Until I get my Anvil (hopefully a week or two) I won't know if I can use  them with the extra 38mm of length, Mike - would you know if longer axles will work with 3" lift and the Anvil or will they create  more problems ?
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #113 on: January 21, 2005, 11:06:57 AM »
If I recall correctly, you are most likely not refering to an american production XL-7...
Air Actuated Diff ?   I'd like to see pics of that.  Ã‚
« Last Edit: January 21, 2005, 11:07:41 AM by whitfield »
  • 416
  • Lil Suzys Dad
Re: now Front Axle Engineering
« Reply #114 on: January 22, 2005, 02:53:31 AM »
It seems that the week link in the CV half shaft is the inner Cup. It's maximum angle is less than the outer and seems to be weaker. All the stronger cv's I have seen use that design as well.
Has anyone thought of or tried using two outer style CV's with a slip spline axle in the middle?
It seems to me that this would provide better operating angles, better reliablity, and strength.
Granted this would be a custom axle as it does not seem to exist in nature, however if it cured the breakage /articulation challenges we have without completely redesigning the front drivetrain it might be worth looking at.
Dave
Offline explosivo
  • 3157
« Reply #115 on: January 22, 2005, 03:20:26 AM »
Dave
Wild's posted about using two outer Tracker CVs and a slipshaft from a sammy, but I believe he mentioned that the slipshaft would be too big (diameter or length, I'm not sure... maybe both) to work... this is where a centered diff would come in handy... having the axles come straight out of the pumpkin rather than having a 2 foot wide differential housing.
omghi2.us[/url]
  • 416
  • Lil Suzys Dad
« Reply #116 on: January 22, 2005, 04:44:58 AM »
I do remember that, I didn't remember the part about the sami slip splines being to long.
Because the standard Cup only allows for about 3" of travel I would guess that you only would need 5 or 6 inches to really have something.
I think the Sami driveshaft slip splines are a good choice. as it keeps it in the family so to speak.
because they are going to have to be welded onto the current axle shaft, I think the slip spline could be cut down to whatever length is needed.
Now if they are too big around that is a different story.
Dave
« Last Edit: January 22, 2005, 04:58:03 AM by sidekicksrock »
Offline explosivo
  • 3157
« Reply #117 on: January 22, 2005, 04:49:20 AM »
I think the Sami driveshaft slip splines are a good choice. because they are going to have to be welded onto the current axle shaft, I think the slip spline could be cut down to whatever length is needed.
Dave
I still think if you're gonna go through with all that work, it'd be more beneficial to just make a custom centered diff so that you have longer CV's which will result in decreased axle angle and shouldn't need as long a slip joint to operate properly.
omghi2.us[/url]
  • 416
  • Lil Suzys Dad
« Reply #118 on: January 22, 2005, 05:14:07 AM »
Maybe your right, I have to agree that in a "perfect world" that a shortened  housing is the best solution. I am really thinking about a solution for people who don't want to completely reengineer the front axle assembly.
Granted the shortened axle solution is probably the one I am going to choose for lil Suzy as well.
Dave
« Reply #119 on: January 22, 2005, 02:21:29 PM »
My slip shaft solution was in conjunction with a
widened front A-arm setup, a total of 4-5 " now
if you have seen a Track/Kick front housing you
know it's not very big, and the additional 2 or so
inches, along with the removed CV cup, you now
have gained a longer CV shaft, about 4" per side,
and about the same as you will gain with a centered
front diff, with out all the hacking and welding.
This would be a bolt in and removeable setup, so
it could be moved to another vehicle, or heaven
forbid, you descide to change back to stock configuration
Zukizzy and I have talked about front drivelines (halfshafts) and I think we can come up with a
solution that will be Zuk based soon
