the transplant is done
  • 1577 Views
Offline mlovetripp0
  • 204
  • do more with less
« on: September 23, 2006, 06:49:06 PM »
 my 1.3 to 1.6 16v swap is done and it starts thank god
87 sammi
Offline droppedtracker
  • 238
  • its a tracker thing, you wouldnt understand!!!
Re: the transplant is done
« Reply #1 on: September 23, 2006, 06:58:31 PM »
congrats bro! :o
« Reply #2 on: September 24, 2006, 08:40:26 AM »
Nice. I'm hoping to get my 1.6 8V installed in the pick up soon. The oil pipe/sump conversion is done and the adapter plate in on order.
Offline mlovetripp0
  • 204
  • do more with less
« Reply #3 on: September 24, 2006, 09:11:55 AM »
how much of a difference is there between a 1.3 8v and a 1.6 8v?
87 sammi
« Reply #4 on: September 24, 2006, 10:15:43 AM »
1.3 8V = 63bhp, 1.6 8V = 80 bhp, 1.6 has much more torque and makes its power lower down too. They look very similar but the 1.6 is a bit taller and has a much stronger bottom end. The 1.3 on mine was pretty worn out so I went for the bigger motor. A 16V would have been nice but the 8V is a much simpler and cheaper swap, early 8Vs over here are carb and have the fuel pump on the head.
How much clearance have you got on the hood? You look to have a fair bit of lift so did you keep the 16V sump (oilpan?)?
« Last Edit: September 24, 2006, 10:18:33 AM by Rhinoman »
Offline mlovetripp0
  • 204
  • do more with less
« Reply #5 on: September 24, 2006, 01:22:36 PM »
standard spoa so i kept the pan the same , and on the hood im still debating , either shim the front up or cut out the support and reinforce the hood,im having to make some mods to the airbox. ive spent all saturday trim wires and cleaning up the rat nest of wire .so far no check engine light .
87 sammi
Offline okcoffroader
  • 27
  • gOt mUd??
« Reply #6 on: September 30, 2006, 06:20:00 PM »
man, that 1.6L 16v is a beast compared to the 1.3 that was in it before....personally im a fullsize guy myself, but i get a kick out of driving his little zuk...that 16v 1.6 feels like it has the torque of a small V8 with those 6.4:1 Tcase gears....i cant wait to get back to the river for some more "zuki fishing".......
http://www.zukiworld.com/forum/index.php?topic=14064.msg128732#msg128732
« Last Edit: September 30, 2006, 06:28:29 PM by okcoffroader »
I thought there was NO REPLACEMENT FOR DISPLACEMENT, until i drove a Zuk with 6.4:1 gears in the transfercase...
