I don't know which wire, but it's
one that comes from the plug on
the back of the Alternator, you got
to insulate both of those, and it sounds
like you got a small hole in the insulation,
you will have to pick up the wires and
make sure they aren't touching any metal,
then try again, if it's not there, look down
the wires and where they go.
I would guess that it's in a spot that rubs
when the engine is running, then as your idling
it will make intermitant contact, blowing the fuse
You could try a 10 amp circuit breaker instead,
it will trip but then it will reset by it's self, about
$5-7 at AutoZone
Follow the wires, it's in there, pay attention to any
spot that is touching or resting on any metal, you
might even just get one of those split wireing looms
and slip the whole Alt wire into it, should stop the
problem if it's in the engine compartment
