Lift complete....for now.
  • 13 Replies
  • 2324 Views
Offline atc_gv
  • 76
« on: September 19, 2006, 09:20:15 PM »
Well here is the GV with 2" BL and boondox coilspacers. Sitting on 30" MT. Had to cut alot off the front wheel wells and some body so it would not rub in reverse at full lock....still does a little. I might add some new springs later and i'll put on the manual locking hubs next.
Offline sir lance
  • 342
  • I love my XL-7
Re: Lift complete....for now.
« Reply #1 on: September 19, 2006, 10:17:53 PM »
how big are the spacers?
and why is your back end saging if the spacers are the same hight?
i have 31"mtrs on my gv and didnt do any cuting.  i only rub at full crank on the frame rail.... with a 2" body lift, and what i call a 3" susp lift but i only used a 1.5" spacer in the front,
you should fit 30's just fine...... even more so with your front bumper cover off....
-Lance
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #2 on: September 20, 2006, 08:53:16 AM »
Please post a pic of your gv!
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline bzzr2
  • 1011
« Reply #3 on: September 20, 2006, 09:06:13 AM »
you need to add another spacer in the back to get it level or a lift spring...  you get probably 2 -2.25 inches in front at least with that spacer.  didn't i mention this 10 times before!?!? ::)
09 taco reg cab short box 4x4
Offline atc_gv
  • 76
« Reply #4 on: September 20, 2006, 10:04:45 AM »
The back end is sagging because I'm not on flat ground. It does not look like that on the pavement. I have 1.5 inch spring spacers front and rear so the back is probably only a 1/4" to 1/2" difference. I might be rubbing because of all my backspacing to fit the rims. They only rub in reverse. Please post some pics and some stats on your GV.
Offline atc_gv
  • 76
« Reply #5 on: September 20, 2006, 10:14:29 AM »
I just did some measuring and the rear is a 1/4" lower.
Offline Moses
« Reply #6 on: September 20, 2006, 07:07:38 PM »
As long as your happy mate, but it can be seen quite clearly that there is a big difference
front to rear and it not surprising if you've used the same spacer all 'round because the
front springs are mechanically disadvantaged nearly 2:1 hence why they are so much thicker
and shorter than rear springs.
Offline atc_gv
  • 76
« Reply #7 on: September 20, 2006, 09:04:00 PM »
Don't bug me none. I plan to get a new bumper and winch eventually which will level it out. This is not my main vehicle for offroading, just a work in progress. You can only do so much to these vehicles and even then the capabability still does not match other vehicles out there. Suzuki just does not care about their offroad market anymore so they keep producing less capable vehicles. I knew before I started that same size spacers make the front end higher, it's pre-runner style  ;D
Offline Moses
« Reply #8 on: September 21, 2006, 01:32:34 AM »
Hey, no worries buddy its your car.
Must be one kick-ass winch   :-X  ;D
Offline atc_gv
  • 76
« Reply #9 on: September 21, 2006, 10:26:13 AM »
Most winches and winch plates are around 100 lbs, add the weight of a new bumper, and throw in a little gravity. :P ;D
Offline bzzr2
  • 1011
« Reply #10 on: September 22, 2006, 10:45:40 AM »
i'm not putting your rig down, do whatever you want with it.
Offline atc_gv
  • 76
« Reply #11 on: September 22, 2006, 03:04:58 PM »
I know, no offence taken. It will be level eventually. The back only took like 45 minutes to do so I'll put a different spacer in next week.
Offline ngrover
  • 131
« Reply #12 on: September 22, 2006, 10:08:22 PM »
I see people say they are running 30 or 31 inch tires.... what is a 245/75R16 considered? According the tire size calculators they are 30.5 but I'm guessing people are rounding one way or the other?
2000 Suzuki Grand Vitara, 5spd. 2.5 inch lift, 225/75R16 AT's
Offline AJMBLAZER
  • 2166
  • Your mom.
« Reply #13 on: September 23, 2006, 07:46:32 AM »
245/75R16 works out to about 31x9.5R16.  Generally they are a little taller than your standard 31x10.5R15 and about an inch narrower.
