Stalling
  • 1852 Views
mperry
Stalling
« on: January 21, 2005, 08:29:27 AM »
My '94 Kick has 87K miles. Starting last spring, it would mis-fire (stutter) for the first couple blocks, when starting off cold, at partial throttle. It doesn't seem to misfire at idle, low RPM or high RPM.
Then, a couple tanks of fuel ago, it would stall in 1st or 2nd gear. (Over half throttle, and when it's warm, it runs fine.) It stalls for 3 to 5 seconds, then takes off again.
The wires, cap, rotor, O2 sensor, sparkplugs, are all new. It only does it when cold.
The shop suggested I do a fuel filter change & "enginevac" (cleans out fuel injector, intake manifold and cylinder carbon). I also had them scope the engine with no results. I've run 4 or 5 cans of water-remover through the gas tank, so I don't think it's water in the fuel.
Now the shop is saying the new wires may be at fault. He's ordering wires and sparkplugs.
What do ya'll think?
Offline adamd
  • 369
  • sofa king we todd it
Re: Stalling
« Reply #1 on: January 21, 2005, 08:39:01 AM »
It very well could be the wires.
'98 kick
3" B/l
30" Mud Kings
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Stalling
« Reply #2 on: January 21, 2005, 09:33:40 AM »
Be careful not to buy cheap wires. The stock ones work best. Ive had problems with aftermarket wires on the 16 valves before.
Mike
Offline SnoFalls
  • 1358
Re: Stalling
« Reply #3 on: January 21, 2005, 10:02:33 AM »
Or be like me and go for a drive with the dist wire half plugged in ... ran like crap till I got home and went DUH!
Offline CBTracker
  • 140
  • OH, you think I can't make it through?
Re: Stalling
« Reply #4 on: January 21, 2005, 10:26:09 AM »
If you have a university around. they have automotive electricians which will usually help out anyone who'll buy them a coffee he he. might have some ideas. could it be injectors? (if its' FI that is)
96 Tracker 2dr on 215s, 2inch suslift soft top, GPS Nav, Light bar.
89 Tracker 2dr hardtop, 235s 1inchsus custom body work, push button starter
mperry
Re: Stalling
« Reply #5 on: January 21, 2005, 01:32:21 PM »
Mike
I guess I did buy cheap ones, but you couldn't tell it by the $35 I spent on them. (He's recommending some that are $2 more, but w/ a lifetime warranty.)
I'm not sure how the wires could cause stalling, but he seems convinced... and he's the expert. (I hope.)  :-X
mperry
Re: Stalling
« Reply #6 on: January 25, 2005, 12:15:05 PM »
No luck, so far. The new wires and plugs didn't seem to help. They are still searching for the prob... and the meter is running.
Didn't someone on here mention that some of the wiring harness joints could corrode? What do you use to clean them?
Re: Stalling
« Reply #7 on: January 25, 2005, 12:26:02 PM »
open up the ecm and see if anything is leaking. or smells burnt.
