coils different side to side?
  • 1611 Views
Offline chet
  • 556
  • Zuki time!
« on: January 25, 2005, 03:44:29 PM »
I tried a search but got WAY too many hits to sift through.
Are the front coils specific from side to side? I put in 2" spacer lift (1.5" in front) and now the pass side is almost 1" higher than the drivers?
What gives? I have checked and nothing is binding and everything is seated right.
Offline biker
  • 730
  • It's a sickness I tell ya
Re: coils different side to side?
« Reply #1 on: January 25, 2005, 04:03:07 PM »
coils are exactly the same, something must be binding up. did you change the camber or toe? try driving the truck back and forth a bit and slam the brakes to see if it will settle more.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
« Reply #2 on: January 25, 2005, 04:04:49 PM »
Could you have gotten one of the coils in upside down?
« Reply #3 on: January 25, 2005, 05:01:51 PM »
The trucklet will be higher until you
move, the tires seem to catch and
hold it up a little, and if you did one
side up in the air at a time this could
be whats happening
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #4 on: January 26, 2005, 01:11:48 AM »
If you've driven it and it's still not level check and see if both springs a rotated correctly into the spring pockets on the bottom.
Offline chet
  • 556
  • Zuki time!
« Reply #5 on: January 26, 2005, 01:57:02 AM »
drove it to work this morning  ;D still seems to have a little bit of a lean. not as bad as before though. Thanks for the help! This IFS stuff is new to me! I'm pretty sure I got the springs rotated correctly but will check tonight when I get home.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #6 on: January 26, 2005, 04:25:28 AM »
Make sure you have it alligned after you get that lean figured out.
Mike
Offline chet
  • 556
  • Zuki time!
« Reply #7 on: January 26, 2005, 06:41:02 AM »
Yep! I got some camber bolts in there and it helped. but I think it has a bit more toe-in now.  ;D
