dist. vac ?
  • 1479 Views
Offline edjeep1
  • i love my sammy !!!!!!!!!!!!!!! !!!!!!!!!!!!!!!
dist. vac ?
« on: January 23, 2005, 10:58:14 AM »
i need to know where to pull vac from for the dist. on a 87 sammy ???
87 samuari 31's spring over FNJEEPS!!
Online ebewley
  • 6552
  • 64
Re: dist. vac ?
« Reply #1 on: January 24, 2005, 03:39:46 AM »
Stock carb?
Offline edjeep1
Re: dist. vac ?
« Reply #2 on: January 25, 2005, 05:45:34 PM »
yes i had a weber but went back to stock just runs better the problem is i cant remember where all the dang vac lines go ??? >:(
Offline AZScr4mbl3r
  • 9
Re: dist. vac ?
« Reply #3 on: January 26, 2005, 12:39:37 AM »
Hey,
Passenger side of the carb there are two ports. I have used both didn't notice any difference although one has an orifice and one is same diameter as the tube. I eliminated the Tee and run straight to the port. I think the Tee went to egr which I blocked off....
-Allen
Offline azrocktrash
  • 121
Re: dist. vac ?
« Reply #4 on: January 26, 2005, 02:06:55 AM »
make sure the one you use has vacume only when you rev the engine or it won't time properly,because the vac advance will be advaced at idle.
   oscar
87 zuk,84 sj410  4 sale
come on,it' only sheetmetal!!
BODY DAMAGE IS ALWAYS AN OPTION
  ~Life begins,where the pavement ends~
Offline edjeep1
Re: dist. vac ?
« Reply #5 on: January 26, 2005, 04:00:21 PM »
thanks for the help man these things are fun dont know why i didn't get one sooner danm jeeps  >:(
