Pinion torque setting
  • 1804 Views
Offline mbmarkyb
  • 461
    • UK Vitara
« on: January 25, 2005, 05:46:18 AM »
Hi guys after replacing my pinion bearings I have come to the point where i need to set my preload by torqueing the back nut .
Would anyone know what the torque setting should be , its now night time here so the dealer is shut and i wanted to finish off this evening any info would be great
Markyb (UK)
UK Vitara JLX SE
Re: Pinion torque setting
« Reply #1 on: January 25, 2005, 12:49:10 PM »
Did you get your new crush sleeve ?
The torque required to crush the new
sleeve is about 300-400, once it's started
the torque required drops off.
The torque spec is like 10-12 Oz Inches on the
bearings, but that is the turning force after
the pinion nut is torqued
Offline 90Stomper
  • 427
« Reply #2 on: January 25, 2005, 01:02:42 PM »
well that is actualy a hard question.
here is what the service manual says...
preload of pinion with an inch pound torque wrench
composite pre-load of pinion bearing and side bearing and compare to values in chart (figure 34).  Example: when pre-load of both pinions is 2.6 kg/cm (5.73 lb. in.), and acceptable composite pre-load of both pinion bearings and side bearngs is 2.8 to 3.2 kg/cm (6.12 to 7.05 lb. in).
the chart is pretty detailed.  if you tell me what your pre-load of both pinions is (value from 1.8 to 3.4 kg/cm) i can tell you what the composit pre-load should be.  but you would have to wait till i get home from work tomorrow nitht :-/  hope that helps.
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #3 on: January 25, 2005, 05:56:54 PM »
yeah i have fitted the new crush sleeve and I had a thought it wasnt a case of a start and end torque.
I have a guide to what it should feel like.  I have a guy to call up that is going to explain .
if i get stuck i will try work it out and get back to you
will let yuo know  cheers,
Markyb (UK)
UK Vitara JLX SE
« Reply #4 on: January 26, 2005, 02:02:09 AM »
The big pain with new gears is the
new crush sleeve, I use the old sleeve
to set the pinion depth and when thats
right, use the new sleeve, this whole process
can take from 1 to 10 tries to get the pinion
depth correct, but once it's set, the new
sleeve will crush down and you set the
rotating force torque
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #5 on: January 26, 2005, 05:49:49 PM »
cheers for your replys its seems that its not something you can follow out of a book , it seems to rely on the feel of it too as some may want a little more than others.
I didnt get around to finishing it last night but i will do tonight as I want to fit the axle back in sat morning and wire in my compressor and air lines
Markyb (UK)
UK Vitara JLX SE
