if that is a factory air line running into the diff how bad would it be to fab up an Air locker? Even if it is vacuum operated...I see untapped potential
 Even if it is vacuum operated... I thought it was pressure operated via the onboard air pump (small pump)!?
Ya, probably be a total lockup or none,but on the other hand, it would be free wheeling the front when disengaged, evenwith the 4WD lever in 4 Low ÂÂ
