Rust Problems??
  • 9 Replies
  • 1854 Views
Offline SunrunnerGT
  • 163
  • 1994 Pontiac Sunrunner GT and 1996 X90
    • Aaron's Suzuki
Rust Problems??
« on: January 26, 2005, 02:03:55 AM »
I have a 1994 Sunrunner GT with two single seats in the back insted of one big bench seat. And I have a big problem with rust forming under them, especially around the hinges, lock down hooks, and all of the welds that hold the rear floor to to car  :'(. (only in the back) is this a common problem?? has anyone heard or seen this happen befor?? My car only has 146,000Kms. Shes my baby  :'(
« Last Edit: January 26, 2005, 02:14:39 AM by SunrunnerGT »
Sunrunner GT, Gold Trim Level
Offline Cwkick
  • 888
Re: Rust Problems??
« Reply #1 on: January 26, 2005, 03:47:44 AM »
I am guessing you are getting water under the carpet and it just sits there and works it's magic (rust).
I would pull the carpet, clean everything up, and repaint or bedliner everything.  Ditch the carpet or get something that breaths better so it doesn't hold water under it.
Cwkick
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
Re: Rust Problems??
« Reply #2 on: January 26, 2005, 04:34:00 AM »
ya thats what i thought too. But theres no sitting water, i check all the time.
« Last Edit: January 26, 2005, 04:34:46 AM by SunrunnerGT »
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Rust Problems??
« Reply #3 on: January 26, 2005, 05:02:42 AM »
Same thing happened to my 91. Thats why I bought my 97 so I could keep up on it. I wash my rig a lot top and bottom to prevent rust.
Mike
Offline Cwkick
  • 888
Re: Rust Problems??
« Reply #4 on: January 26, 2005, 07:57:04 AM »
My 97 had some very minor surface rust under the carpet.  But, yes it was dry under.  Them I checked the stupid sound deadening pad.  It was very moist.
Pulled the carpet and the pad fell off because the moisture softend the glue.  The rust literally wiped up with a rag.  Glad I caught it.
Cwkick
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
Re: Rust Problems??
« Reply #5 on: January 26, 2005, 08:07:27 AM »
Clean it up and apply POR-15. Don't just clean it and bedliner over it... POR-15 is much better at stopping rust (however, feel free to bedline over POR-15.
'87 TinTop
'04 F-150
Offline SnoFalls
  • 1358
Re: Rust Problems??
« Reply #6 on: January 26, 2005, 08:50:19 AM »
This is the reason I pulled my carpet first thing when I got my tracker. The carpet "felt" dry, but when I pulled it, the pad was sopping wet.
I made sure I took any surface rust away with a wire wheel and then herculined. I did end up cutting down some of the carpet (without pad) for a cover of the trans hump, but that was just for looks and some sound deadening.
Offline SunrunnerGT
  • 163
    • Aaron's Suzuki
Re: Rust Problems??
« Reply #7 on: January 26, 2005, 10:55:23 PM »
is it a big job to cut out the old rear floor, and weld a new one in?? Coz mine might be that bad.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
Re: Rust Problems??
« Reply #8 on: January 27, 2005, 07:25:42 AM »
Yes thats a huge job. How good are you at welding? ::)
Mike
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
Re: Rust Problems??
« Reply #9 on: January 27, 2005, 11:13:26 AM »
This why I spend $90 a year getting my Sidekick "Rust Proofed" every year.  It's still develops here and there, but I can handel it.
Rust under the rear seats is a huge problem with Sidekick/Tracker.
