TDC marking on Tranny
lacrosse10604
50
I Love ZUKIWORLD!
September 03, 2006, 08:53:47 AM »
I've got a 93 kick, 4dr, 5spd. I'm trying to find TDC. I know I need to view the flywheel marks through the tranny. I can't find the slot on the tranny to look through. Can't someone give me a decription of where its at or a pic?
Thanks,
Dave
Searching for a donor for my diesel build.
wildgoody
8134
67
Re: TDC marking on Tranny
September 03, 2006, 09:07:08 AM »
I don't think my Auto trans has one, the
Man trans has this???
You can find TDC from the timing marks on the
front pulley too, sorry I can't be of more help
on the flywheel marks.
lacrosse10604
50
I Love ZUKIWORLD!
September 03, 2006, 09:22:59 AM »
I thought they had it, but since I can't find it and yours doesn't either maybe they don't. I'm doing the diesel swap and the kick engine has long since been removed.....
wildgoody
8134
67
Reply #3 on:
September 03, 2006, 09:35:17 AM »
The VW engines have a timing hole and a mark,
this I know. What Diesel are you using
I'm thinking about a Diesel swap and adding a turbo
(got to have a turbo
) for my kick
Good Luck
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #4 on:
September 03, 2006, 10:00:48 AM »
Flywheel marks are only on the 1.3 engine.
http://www.rhinopower.org
lacrosse10604
50
I Love ZUKIWORLD!
Reply #5 on:
September 03, 2006, 10:30:40 AM »
I've got a VW 1.6TD "installed" (almost running)...
ack
1659
34
Professional askhole
Reply #6 on:
September 03, 2006, 07:03:07 PM »
Quote from: Rhinoman on September 03, 2006, 10:00:48 AM
x2 on that -- except it's the transmission bell housing on the SJ-413/Samurai that has the viewing hole for the timing marks on the edge of the 1.3 flywheel.
Not being familiar with Diesels, I would say that removing the timing belt cover to expose any markings on the front of the crank will solve the problem.
There is a Diesel forum at Zuwharrie.com and on Yahoo Groups that might be a source of information for you. You can find several Diesel links - including the ones mentioned above - at Ack's FAQ (the link is in my signature) by typing in
diesel
as a search word.
Ack
Ack's FAQ
http://www.acksfaq.com
