Samurai compression results
  • 4714 Views
Offline 1eugene445
  • 8
« on: August 31, 2006, 08:41:00 AM »
I just did a compression check on my '87 Samurai which has over 100,000 miles. #1 was 149, #2 was147, #3 was 145, #4 was 146.
These numbers seem awfully good and surprisingly high. They were done with a lightly warmed engine, all plugs removed at the same time and cranked for a good 5 seconds.
What is the opinion of anybody who knows what they should be.?
Eugene
Re: Samurai compression results
« Reply #1 on: August 31, 2006, 09:06:29 AM »
Sounds good, all the #s are close together too,
good tight engine.
Offline kymike
  • 87
« Reply #2 on: August 31, 2006, 07:19:50 PM »
those numbers are great but i am not sure about taking all the plugs out is that the way you are suppose to do it i want to do mine i think they say the motor needs to be turning at 400 rpm and iam not sure if a stock starter will spin one that fast
Offline RGERBER
  • 81
« Reply #3 on: August 31, 2006, 07:31:51 PM »
do a goggle search on compression tests, i thought it was 1 at a time
94 SUZUKI SAMURAI / 1.6 8 VALVE TRACKER MOTOR.
« Reply #4 on: August 31, 2006, 07:48:04 PM »
The way I was tought was remove all the plugs
and throttle open when you crank the engine.
Either way the engine #s look good
Offline holeypockets
  • 68
  • i think DENTS are pretty
« Reply #5 on: September 01, 2006, 05:23:03 PM »
my haynes book said minimum was 199lbs.  i don't really trust this,  what do other books say?
i just like dents, i don't know why.
« Reply #6 on: September 01, 2006, 11:44:50 PM »
199 PSI LOL, Way too high
Check and make sure that's not for a Diesel engine  ;)
« Reply #7 on: September 02, 2006, 06:37:09 AM »
Thats the usual way. If you have electronic ignition then you should disconnect the plug to the distributor too
« Last Edit: September 02, 2006, 06:39:20 AM by Rhinoman »
« Reply #8 on: September 02, 2006, 07:36:53 AM »
Ohh ya, I always ground the coil lead too,
just to be safe, don't want any blown igniters
