PR: Technical Specs for new XL7
  • 0 Replies
  • 3103 Views
  • 6554
  • 64
« on: August 30, 2006, 09:38:47 AM »
2007 Suzuki XL7
ENGINE
Type:            3.6-liter, V6, 24-valve DOHC (Suzuki N36A)
Materials:         Aluminum cylinder block/aluminum cylinder heads
Displacement:         3.6 liters (3,564 cc/217 cu. in.)
Bore x stroke:         94.0 mm x 85.6 mm/3.70 in. x 3.37 in.
Compression ratio:      10.2:1
Horsepower:         252 hp |removethispart|@ 6,500 RPM
Torque:         243 lb.-ft. |removethispart|@ 2,300 RPM
Valves per cylinder:      Four
Fuel system:   Electronic multi-port fuel injection, variable induction system, in-tank fuel pump
Emission compliance:   Dual, close-coupled catalytic converters, positive crankcase ventilation, intake and exhaust cam phasers with internal exhaust gas recirculation and evaporative emissions system
Exhaust:         Dual, stainless steel
TRANSMISSION
Five-speed automatic (AF33-5 Aisin AW) with manumatic control
1st            4.68:1
2nd            2.94:1
3rd            1.92:1
4th            1.30:1
5th            1.00:1
Reverse         3.18:1
Final drive ratio      2.48:1
ALL-WHEEL-DRIVE SYSTEM
Electronically controlled, on-demand all-wheel drive.  PTO on transaxle with rear-mounted electronic clutch pack delivers torque to rear wheels as necessary.
SUSPENSION
Front:   Independent:  MacPherson strut suspension with coil springs, hydraulic shock absorbers and 26 mm anti-roll bar.
Rear:   Independent:  Multi-link (four link) suspension with coil springs, hydraulic shock absorbers and 20 mm anti-roll bar.  Seven-passenger versions are fitted with Nivomat load-leveling shock absorbers.
STEERING
Type:   Hydraulic, power-assisted, fixed-ratio rack-and-pinion
Overall ratio:   17.1:1
Turns, lock-to-lock:   2.7
Turning circle:   41.8 ft. (12.7 meters) curb-to-curb
BRAKES
Front:   Power-assisted vented disc (11.6 in./296 mm) with floating two-piston calipers and pad wear sensors
Rear:   Power-assisted disc (11.6 in./296mm) with single piston calipers
ABS:   Standard, four wheel, four channel with electronic brake-force distribution (EBD)
Traction control:      Standard, engine torque reduction
Electronic Stability
Program (ESP)1
(including traction control):    Standard
WHEELS         16 x 6.5-in. alloy
            17 x 7.0-in. alloy
            17 x 7.0-in. chrome plated alloy (Platinum Touring Package)
TIRES            P235/65R16
            P235/60R17
Spare:            Full-size spare
EXTERIOR DIMENSIONS
Wheelbase:         112.4 in. (2,857 mm)
Overall length:         197.2 in. (5,008 mm)
Overall width:         72.2 in. (1,835 mm)
Overall height:         68.9 in. (1,750 mm)
Tread width, f/r:      61.6 in. (1,565 mm)/61.8 in. (1,570 mm)
Overhang, front:      37.5 in. (953 mm)
Overhang, rear:      46.5 in. (1,181 mm)
Ground clearance:      7.9 in. (200.6 mm)
Approach angle:      17.5 degrees
Departure angle:      20.0 degrees
INTERIOR DIMENSIONS
Headroom
Front:   41.3 in. (1,048 mm)
   Rear:         40.0 in. (1,015 mm)
   Third:         38.8 in. (986 mm)
Legroom
   Front:         41.2 in. (1,047 mm)
   Rear:         38.8 in. (986 mm)
   Third:         30.9 in. (784 mm)
Shoulder room
   Front:         55.6 in. (1,413 mm)
   Rear:         55.3 in. (1,405 mm)
   Third:         50.0 in. (1,270 mm)
Hip Room
   Front:         52.2 in. (1,325 mm)
   Rear:         53.1 in. (1,350 mm)
   Third:         38.2 in. (971 mm)
Interior volume:      103.5 cu. ft.
Maximum cargo volume:    95.0 cu. ft.
CAPACITIES
Fuel tank:         18.6 gallons (70.3 liters)
Engine oil:         5.0 quarts (4.8 liters) with filter
Engine coolant:   12.7 quarts (12.0 liters) – two-row configuration
   13.1 quarts (12.4 liters) – three-row configuration
CURB WEIGHT
2WD, auto transmission:   3,886 lbs. (1,763 kg)
AWD, auto transmission:   4,049 lbs. (1,837 kg)
Weight dist, f/r:      57 percent/43 percent
Payload:          1,127 lbs. (511 kg)
TOWING
2WD, auto transmission:   3,500 lbs. (1,587 kg)
AWD, auto transmission:   3,500 lbs. (1,587 kg)
EPA FUEL ECONOMY ESTIMATES
2WD, auto transmission:   18 mpg/city and 24 mpg/highway
AWD, auto transmission:   17 mpg/city and 23 mpg/highway
1ESP is a registered trademark of DaimlerChrysler AG
