Driveshaft clearence
36zuk
37
I love YaBB 1G - SP1!
January 23, 2005, 02:19:45 PM »
I have the RRO trailblazer kit with 3in springs. My driveshaft is hiting my Transmission xmember how can i get that clearence.
Last Edit: January 23, 2005, 03:02:26 PM by 36zuk
mudfkr
Re: Driveshaft clearence
January 23, 2005, 04:09:38 PM »
My mates running that same kit in his "90 Sammy and he had to cut the x- member up a bit, not tidy but it works :-/.
nitromax
206
FunZilla's alive !
January 24, 2005, 02:54:24 AM »
Not too much help here, not what I've seen somewhere else
1600 cc 8v, MegaSquirt EFI, Camden SuperCharger, Calmini 3" Shackle Reversal, IronMan 3"suspension lift, SPOA and 2"bodylift, 4.16 T-case, QuickLok rear, 33x12.5 ProComp XT's on 8"rims with 1"wheelspacers.
Check it all on :
www.nitromax.nl
International editor |removethispart|@
www.izook.com
track_this
332
Live for something or die for nothing
Reply #3 on:
January 24, 2005, 07:39:04 PM »
i think rock4xfabrication.com has a high clearance front crossmember if i recall correctly.
shane
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
rockrat
196
Got Ringr
Reply #4 on:
January 28, 2005, 03:02:10 PM »
Yep we do.. replaces the stock x-member completely. 100% bolt in and allows you to cut the stock x-member out and ours goes up and over the driveshaft allowing as much droop as your shaft can physicaly go.
HotRod
4334
2
95 Tracker
Reply #5 on:
January 28, 2005, 03:43:11 PM »
Is it wide enough to fit a SideKick with a Sammie T-case?
