How do you turbocharge a trackick and get it to pass smog in california?
  • 2427 Views
Offline urbanwheeler
  • 696
I was thinking of mildly turbo charging my tracker, but I dont know how I would get it to pass the stupid visual inspection when I get it smogged in california. Any sugestions? I also was wondering how to get more fuel through the single injector so it wouldnt run lean.
Offline Mike71
  • 1449
not much help here no the smoggin but i might be able to help with the fuel.
do you have an 8v or 16v?
You cannot add a turbo and be legal.
You can flow a little more fuel, but only
to get 2-3 PSI boost.
Answer, do a Diesel swap, get a Smog
Exempt Cetification, Diesels don't get
smogged, at least early ones don't and
now you can swap any engine with no
smog problems.
Offline keith
  • 1176
smog problems.
Wild, how do you get around smog?  Is this what you did?
Not yet, I have a friend that has selective
sight, as long as I blow the right #s he's OK
with it.
Offline gravity_storm
  • 108
  • The wino and I know
A friend of my nephew had a late model Trans-Am with a turbo that was mounted in the back of the car underneath just in front of the back bumper. I can't imagine that it was as efficient as if it were under the hood where it belongs but looking under the hood you would have never known it was a turbo. According to my nephew it would blow away the normally aspirated Trans-Ams and Camaros of the same vintage so maybe it works. Seems like there would be a hell of a lot of lag but maybe I'm wrong.
Probably your best bet is a good old fashioned bribe!  :o ;D
1996 Sidekick, 1.5" homegrown body lift, 2" Digger suspension lift, home made snorkle, front skid
  • 696
If I was to convert it to diesel, I might never go back to gasoline :P ;D But then you could turbocharge the diesel ;D Has anyone done a diesel swap on a trackick?
Offline Yoak
  • 577
There have been several that have been done. If you do a search you will see a few.
I think this is the way I am going to go as well....which means I will have an 8V turbo for sale soon  :D
