[AUTO OR MANUAL] Which transmission is easiest to replace ?
  • 1481 Views
Jayzuki
« on: August 25, 2006, 11:40:59 AM »
What transmission would be the least complicated to replace?
Thanks
« Last Edit: August 25, 2006, 11:42:39 AM by Jayzuki »
Offline 4njeep
  • 113
  • I Love ZUKIWORLD!!!!
Re: [AUTO OR MANUAL] Which transmission is easiest to replace ?
« Reply #1 on: August 25, 2006, 11:47:01 AM »
personaly i think they would be about the same. its just a little messyer to drain the fluid out of the auto, and the tc has to be unbloted from the flywheel. other than the shifter they are pretty much the same i think.    I just changed the auto in mine and it wasnt really that hard.
92 sidekick jlx auto
2" suspension lift
5.13 gears, locked rear.
30x9.5 goodyear mt/r's on CSA Scorpion's
Offline biker
  • 730
  • It's a sickness I tell ya
« Reply #2 on: August 25, 2006, 08:49:02 PM »
4njeep
What was wrong with your old tranny?
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline 4njeep
  • 113
« Reply #3 on: August 26, 2006, 02:53:25 AM »
4njeep
i think the seals were old and hard. didnt really want to shift for the first couple miles. other than that it was fine, I got a used one from the wrecker for $100 with the transfercase and tc. it was cheaper than rebuilding it. the new one works great. (knock on wood)
2" suspension lift
Offline biker
  • 730
« Reply #4 on: August 26, 2006, 09:51:46 PM »
Which wrecker did you get it from?
99 Vitara 2wd
10 Gr Vitara
Offline 4njeep
  • 113
« Reply #5 on: August 26, 2006, 10:16:10 PM »
i got it from BC auto wrecking, they had three of them when i was there. but now they are just melted piles of goo.. when i was there though, they had 5 trackicks.
2" suspension lift
