your better off putting in either a swift gt motor or the 1.6l motor
http://www.teamswift.net/viewtopic.php?t=10938
Quote from: droppedtracker on August 23, 2006, 11:00:06 AMhttp://www.teamswift.net/viewtopic.php?t=10938G13BB engine is the same as the Jimny, with the EFI it makes 80bhp - same as a 1.6 8V. Downside is that it is higher revving with less torque and max torque around 1000rpm further up the rev range. G13BB head on a 1.6 should be pretty good, I'd like to that to the Jimny eventually but the stock engine only has around 30k on it.
Quote from: Rhinoman on August 23, 2006, 12:59:37 PMQuote from: droppedtracker on August 23, 2006, 11:00:06 AMhttp://www.teamswift.net/viewtopic.php?t=10938G13BB engine is the same as the Jimny, with the EFI it makes 80bhp - same as a 1.6 8V. Downside is that it is higher revving with less torque and max torque around 1000rpm further up the rev range. G13BB head on a 1.6 should be pretty good, I'd like to that to the Jimny eventually but the stock engine only has around 30k on it.that sounds like it whould be a badass Jimny! i think it's sad there is so little jimny talk here :'(
