tail shaft on its way out????
  • 1751 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« on: January 05, 2005, 08:41:24 PM »
are there any known common problems with the Vitara/Sidekick tail shafts? more so rear?
i've got a clicking when ever force is transfered initially in either forward or reverse.
i've got it down the being either the rear diff, or rear tail shaft, and its everytime i drive it now. everything looks 'normal' underneath, but was wondering if it was the UNI joints in the tailshaft.
thanks for any help
« Last Edit: January 05, 2005, 09:00:05 PM by sikid_01 »
Crabzuki
Re: sadasdas
« Reply #1 on: January 05, 2005, 08:51:51 PM »
I had this problem too and solved it by changing the old u-joints and going with greaseable ones. ~ CZ
Re: tail shaft on its way out????
« Reply #2 on: January 05, 2005, 09:09:31 PM »
I  would bet it's old dried up U joints too ;)
mudfkr
« Reply #3 on: January 06, 2005, 04:16:07 AM »
If it's not U joint related and you've been playing in water and not checking your diff oils  ???, It could be a collapsed pinion bearing as well.
I swapped out a GQ Patrol  rear LSD the other week for a guy who hadn't changed his diff oil (which was like cream cheese :o) after water wheeling just because he didn't want to invest the $30 in  oil, ended up costing $475 in the end and thats with no  labor.
« Reply #4 on: January 06, 2005, 02:56:54 PM »
You smoked your joints  ;)
and I don't mean the herbal ones
Offline explosivo
  • 3157
« Reply #5 on: January 06, 2005, 09:33:50 PM »
Hell, even if it's not U-joints (which it probably is) you'll probably want to replace those anyway if you haven't done so in a while. U-joints popping out while you're driving down the road is no treat, trust me :-X
omghi2.us[/url]
Offline SiKiD_01
  • 574
« Reply #6 on: January 30, 2005, 11:49:24 AM »
OK, now that i have a set on new uni's, greasable ones at that!, how the heck do i get the old ones out, and the new ones in?
sometimes i just wish i had a shop manual for stuff like this.
thanks
Steve
« Reply #7 on: January 30, 2005, 01:40:14 PM »
Take it to a machine shop (automotive)
and have it done, unless you feel like
buying an H frame press to press them
out, if you try to do the hammer method,
you might just mess up the yokes
