R & P install guide?
  • 1846 Views
Offline 90Stomper
  • 427
« on: January 29, 2005, 01:48:36 PM »
anyone know if there is one with pics for a trackick?
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
Re: R & P install guide?
« Reply #1 on: January 30, 2005, 01:34:34 AM »
there may be some here.
http://www.izook.com/tech/
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Bfunk
  • 406
« Reply #2 on: January 30, 2005, 03:32:02 AM »
If you are new to this, it probably means you don't have a way to measure backlash.  Don't do it yourself until you can measure your backlash.
Brian
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #3 on: January 30, 2005, 11:24:01 PM »
I have just done my ARB install and i had to replace the bearings on all parts , I havent gone into detail on the pinion bearings but there are some  pictures here http://www.markyb.co.uk
I am no expert and would recomend getting some one to do it for you , I will in the future as i had a couple of days scrating my head until I borrowed the correct tool from a garage and set my preload correctly.
Markyb (UK)
UK Vitara JLX SE
Offline tracker8wr
  • 568
    • my home page
« Reply #4 on: January 31, 2005, 05:39:00 AM »
actually u can take the third member to a tranny shop and they can measure ur backlash for u and abjust it if need be. it shouldn't be more than $20 or so just be nice and they might hook u up.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline 90Stomper
  • 427
« Reply #5 on: January 31, 2005, 01:15:11 PM »
 ;Dawsome as always, thank you all.  and what exactly do you use to measure backlash?  yah, i have never done this before.  but i never really worked on cars till last year either.  fearless baby!!!  LOL
Offline Rollerskate
« Reply #6 on: January 31, 2005, 02:39:52 PM »
Back lash is measured with a dial indicator and you'll need a means to hold it,like a magnetic base. There's some other concerns when setting up gears.You need to adjust preload on the pinion and carrier bearing. A sensitive torque wrench with a range of about 30 inch/ponds or a spring tension scale is used to measure the preload. Also pinion height must be checked/adjusted. Marking compound is placed on the gear teeth and after a few rotations the pattern is read.
This will tell you if the pinion height is correct.
 As you can see there quite a bit to properly setting-up a third member. If you're serious about doing it yourself I suggest you get the Suzuki FSM. It's the best source of info for this job.
I never asked for nothing and thats all I got.
