camber bolts
  • 1129 Views
mozone
camber bolts
« on: August 08, 2006, 06:29:24 PM »
is it a good idea to use 4 of these an my gv? i would just like to get the opinions of some more people that have used them. thanks.
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: camber bolts
« Reply #1 on: August 08, 2006, 07:41:00 PM »
You only need 2. You keep the factory bolts on the bottom.
Offline mfoster442
  • 29
Re: camber bolts
« Reply #2 on: August 09, 2006, 10:41:34 AM »
I recently just installed camber bolts on on '02 Vitara, and they seem to be working great.
As TN_Tracker suggests, you should only need two of them installed in the top holes.
Good luck.
2002 Vitara
235/70/R16 Cooper Discoverer S/Ts
Stock engine and running gear
Boondox Spacers
Pro-Comp Shocks Strut extenders Camber bolts
