Winch Recommendations?
  • 34 Replies
  • 6798 Views
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Winch Recommendations?
« Reply #15 on: January 27, 2005, 01:13:52 AM »
Thanks for the tips! That synthetic rope/cable sure seems like a good idea.
It's more than a good idea, it's REQUIRED in several competition groups:
Synthetic winch rope is currently required by the following:
UROC
ERoCC
NEUROC
Mike I can't believe you went to 3/8" for the COLOR!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: January 27, 2005, 07:22:56 AM »
Yea I know, but blue and orange just dont look right. :P Hey at least I dont haveDubs with spinners! ;D
Mike
Offline chrisvitarasport94
  • 228
« Reply #17 on: January 31, 2005, 08:26:10 AM »
how much does the nose dip when you add the weight of a winch bumper & winch?
what can you do about it ? (I already run RRO spacers as part of my spring & spacer lift)
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #18 on: January 31, 2005, 08:54:57 AM »
You could add a stronger set of coils. Are you running stock coils? Add a set of 4 door coils for about an inch of lift.
Mike
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #19 on: January 31, 2005, 09:01:31 AM »
Well, yeah, they might run you out of Minnesota, for having Bronco colors!
The "nose dip" question is a good one - the Calmini lift comes with beefier springs that compensate for that weight - the bumper and winch have GOT to weigh a few hundred pounds together!  As much as the ENGINE!!!
Bob
  • 228
« Reply #20 on: January 31, 2005, 09:10:05 AM »
I run +1.5" Ironman uprated springs, with RRO 1" spacers, all round, and don't really want to have to replace them.
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #21 on: January 31, 2005, 09:14:21 AM »
I had OME heavy duty springs on the LWB in preparation for fitting the winch. When it went on, the front dipped a little but not much. When I swapped to the Calmini 3" I kept my OME struts and still used the Calmini strut spacers and it sits level.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #22 on: January 31, 2005, 09:16:37 AM »
Ya know the rubber bushings that go on top of the coils? Get a pair of them from the salvage yard and trim the bottom lip off. Works good as a shim to help level things. :-/ One of those equals almost 1/2 inch in the front.
Mike
Offline chet
  • 556
  • Zuki time!
« Reply #23 on: January 31, 2005, 09:36:58 AM »
A piece of that white cutting board stuff works good as top up spacers as well! its 3/8" thick and easy to cut.
mudfkr
« Reply #24 on: January 31, 2005, 09:50:51 AM »
Hey while we're on the winch subject here what's your preferred brand and why,
price ?
proved reliability ?
weight ?
Amount of rope it holds ?
Color ? (for Mike anyway  ;D)
Mine was Warn only for the fact I got it second hand off a young guy who had it on a Yota mini truck just cause he though it looked cool with it (he never used it once) ???  If this one hadn't come up I don't know if I would of brought a cheaper brand (Chinese) one or still gone for the warn or superwinch.
Offline cj
  • 1276
« Reply #25 on: January 31, 2005, 09:56:29 AM »
Ramsey 8000 'cause I picked it up cheap and it would fit in my ARB bar  ;D
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #26 on: January 31, 2005, 10:36:36 AM »
Im running an M6000. I love it. Its fast, strong, and the price wasnt bad either.  I mounted the solinoids under the hood to keep them out of the enviroment. It has been very reliable.
Mike
mudfkr
« Reply #27 on: January 31, 2005, 10:45:34 AM »
I put mine in the back so didn't have to get mud on my boots  ;D
I didn't have a lot of room in the engine bay and didn't want it on the front either so I decided to put it back there with the battery. Works good too, only my winch bitch has to get out now  ;D
Offline cj
  • 1276
« Reply #28 on: January 31, 2005, 02:45:16 PM »
Mines under the hood with the hand controller plug mounted in the grille and a switch inside as well.
Offline HUMZUKI
  • 117
  • Fool!
« Reply #29 on: February 01, 2005, 01:30:22 AM »
Not with the Ramsey and the DIY  mount from Shrockworks thats less than a 100lbs total
