Gear reduction for Kick?
  • 47 Replies
  • 9079 Views
Offline hcgalvin
  • 1695
    • Granite Path
Re: Gear reduction for Kick?
« Reply #45 on: February 01, 2005, 12:35:34 AM »
Yep.
Lots of gear combinations.
Heather Galvin
Offline phoenix827
  • 44
« Reply #46 on: February 01, 2005, 10:41:17 AM »
ok, now how does this compare to a 4.1 or 6.1 tcase?
Aside from the extra gears you get, Which would be better for stock gearing, (axle) and say 33-34" tires on the street?
What about the trail?
Got a rough idea for cost for dual cases?
Am I asking enough questions? ;D
Offline Natebert
  • 1098
« Reply #47 on: February 01, 2005, 01:26:45 PM »
We have a 4.24:1 in one of the cases, the sidekick case.
This is great for the slow, crawly stuff.
We have stock Sammy gears, ~2.2:1 in the Sammy case, for regular like 4wd low.  (like most of the rest of the planet)
But combine them together (4wd low + 4wd low) and put the tranny in 1st gear and it will climb nearly anything at idle.  (overall crawl ratio is ~180:1, when stock sidekick is ~34:1)
Overall I'd say that by just doing the dual t-cases in a sidekick (Sammy +Kick cases) you wouldn't need diff gears and would be easily able to handle 33s on the street without issue.  (the Sammy has a reduction in high)
OTT Kicker 3 = ~$600 US.  (Send them a Sidekick t-case to modify)
Sammy T-case = ~$150 US.  (Average price from a junkyard)
Added together it's cheaper then a set of 4.24:1 gears alone.
But you may have to add the costs for custom drive lines, custom cross members, custom body work, etc.  (Which you can do yourself) to accomodate the additional t-case, shifter and moved output shafts.
~Nate
« Last Edit: February 01, 2005, 01:29:58 PM by natebert »
