Gear reduction for Kick?
  • 47 Replies
  • 9078 Views
Offline cj
  • 1276
  • I drive a really big ATV
Re: Gear reduction for Kick?
« Reply #30 on: January 26, 2005, 10:10:08 AM »
thats what im dooing on my other track,only using samy trans ,i think i may have gone too low with gearing, are 5.71s gona kill my highway speeds with 4to1 t/case gears?
annyone?
5.71's and a Sammi t-case with 4:1 gears and 35's = high rpm and low speed in high range
Offline szabotage
  • 114
  • snaggletooth
« Reply #31 on: January 26, 2005, 10:17:18 AM »
just something to keep in mind, the higher the gear ratio in your diff, the weaker the ring gear will be,
I ran 5.13 kick fronts in my sammi with a locker in the rear and only got 500k before grenading the ring gear. and only got like 2 trail runs in.
now I run the 5.13's from the rear and seem to be running good. but I wouldn't trust it to any higher ratio unless I upgrade to toy axles
Offline mesjr2004
  • 422
« Reply #32 on: January 26, 2005, 10:51:31 AM »
im running toy axles,
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #33 on: January 27, 2005, 09:56:49 AM »
Okay, but for once (I couldn't find it in the search), explain to me how I'd calculate the needed/ accomplished gear ratio's. Whith a formula or something. Does anyone have such thing? Maybe even the stock ratio'a of all 5 gears in a sidekick/tracker/(european) Vitara thing. And as 3rd question the ratio'a of the 4.10/4.16/4.13/samurai transfer cases?
I know it's a lot questions but I really wanna know because of my probable set-up.....  :-/
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
Offline zooky
  • 135
« Reply #34 on: January 27, 2005, 10:33:04 AM »
if you got 500k with that set-up I wouldnt complain about grenading the ring gear
« Reply #35 on: January 27, 2005, 11:45:56 AM »
That's like about 300-350 miles
not too good
Offline szabotage
  • 114
  • snaggletooth
« Reply #36 on: January 27, 2005, 01:01:09 PM »
lol, yup I think I was halfway through my second tank of gas from the time I got them installed that the ring gear decided to grenade ;D
500 kliks, not 500,000 ;)
« Reply #37 on: January 27, 2005, 03:26:18 PM »
I would say that you didn't set up the diff
right, that's about the only way to destroy
a R and P set, even set up poorly you should
get several thousand miles before failure.
Of coarse I wasn't there to see the setup
so I shouldn't comment on it being right
or wrong, this is just an experience baised
statement, I nuked a set of R and P in an
Audi I had, that one required shims to set
up, and the |removethispart|@$$ wipes at the machine shop
screwed up the thickness I requested, I put
it together anyway and it lived 5 or 6 months
I never saw the nuked set, but it began to whine,
louder and louder day by day, until one day it
went in grand style, chunk bang clunk vroom
free reving engine   :o  nuked gear set
Offline Natebert
  • 1098
« Reply #38 on: January 30, 2005, 03:24:22 AM »
I'd say that this is how most R & P sets go bye, bye.
~Nate
(at least thats how 2 of ours went)
Offline Baloo
  • 84
« Reply #39 on: January 31, 2005, 05:21:36 AM »
 ???So is anyone running dual cases in a Sidetrack? It seems easy enough to add a Sammy case after the stock case. Might be a bit long for a two door but a 4door would be ok. Drive angles would be funky but a cv may be a cure. Any info here?
Offline Natebert
  • 1098
« Reply #40 on: January 31, 2005, 05:27:39 AM »
Yup.
Works great.
vvvvv from OTT's website vvvv
vvvvv from our work bench vvvv
Sticks inside cab;
From underneath;
« Last Edit: January 31, 2005, 05:35:16 AM by natebert »
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #41 on: January 31, 2005, 05:28:37 AM »
Yup.
http://www.ottindustries.com/kicker3.htm
« Last Edit: January 31, 2005, 05:32:40 AM by hcgalvin »
Heather Galvin
Offline Natebert
  • 1098
« Reply #42 on: January 31, 2005, 05:36:22 AM »
Shouldn't be to long for a 2door.  They are made for 2dr sammies.
~Nate
Offline phoenix827
  • 44
« Reply #43 on: January 31, 2005, 09:06:34 PM »
Now do you keep hi and lo range in BOTH cases? I thought I saw in one of the links to another page that one case was locked in lo. ??? If I am understanding this right, this would give you street gears in hi-hi, and rock gears in lo-lo with bigger tires. am I right?
« Reply #44 on: January 31, 2005, 09:28:09 PM »
You should be able to run Hi or low in the ftont case, than 2hi, 4hi , 4low in the rear case giving you many combinations of gearing 2 and 4wd.
