G/V tires and wheels?
  • 16 Replies
  • 2775 Views
Offline FullDraw
  • 15
Re: G/V tires and wheels?
« Reply #15 on: August 09, 2006, 10:57:13 PM »
Moses your running L/T tires like I will be running are the 10 ply or 8 ply just wondering to see how the ride is at 40 psi, The tires I want to run are 10 ply and need a higher psi like you stated. I should of just asked what the psi rating was on a stock aluminum 16" wheel and avoided all the jabber, I liked the Volvo comment ;D
FullDraw
Offline Moses
« Reply #16 on: August 10, 2006, 02:28:42 AM »
Its good to see someone has a sense of humour  :D
I'm using Goodyear Wrangler ATS's, unfortunately they don't give a ply count.
I would say for me 40psi is comparable with the factory tyres,
I could go higher but am using harder springs which ride pretty
rough so I keep it there for comfort. If the car is empty I drop
the rears to about 35, any less and they start to bulge a little.
20-25 on dirt tracks and rock gives good grip and comfort, 12-14 on
beach sand works well.
I cant imagine the alloy rims being a limiting factor, they are generally
stronger than steel rims and my van requires 60psi on those.
Trial and error is the only way to know what works best.
